time step of twophaseeulerfoam
Like Tree1Likes
  • 1 Post By rdbisme
Old   July 2, 2020, 12:02
Question time step of twophaseeulerfoam
kimy
qi.yang@polimi.it is on a distinguished road
Send a message via ICQ to qi.yang@polimi.it Send a message via AIM to qi.yang@polimi.it Send a message via Yahoo to qi.yang@polimi.it
Hi guys,
I am using twophaseeulerfoam to simulate the solid-liquid pipe flow. The total number of the cells are 180000 (unstructure mesh) but I need to set a very very small time step to keep simulation normally runnning. Do you have any suggestion that I can define a larger time step? I saw some people used this solver to simulate the same phonomenon. They used more cells than mine. I cannot imagine how much time they used to finish one simulation if the situation like mine.
Thanks,
qi.yang@polimi.it is offline   Reply With Quote
Old   July 2, 2020, 14:40
rdbisme's Avatar
Ruben Di Battista
rdbisme is on a distinguished road
Originally Posted by qi.yang@polimi.it View Post
Hi guys,
I am using twophaseeulerfoam to simulate the solid-liquid pipe flow. The total number of the cells are 180000 (unstructure mesh) but I need to set a very very small time step to keep simulation normally runnning. Do you have any suggestion that I can define a larger time step? I saw some people used this solver to simulate the same phonomenon. They used more cells than mine. I cannot imagine how much time they used to finishone simulation if the situation like mine.
Thanks,
Hello qi.yang, I think you might get more helpful comments if you give more details about your configuration. You can check my old post for an example of which details might be interesting.
rdbisme is offline   Reply With Quote
Old   July 2, 2020, 20:47
Ardalan
Ardali is on a distinguished road
Hi guys,
Thanks,
If you do not need energy equation discard it in the solver.
If you need it specify correct boundary conditions in T files.
diameterModel in phaseProperties matters as well.
If comprisibility matters to you a lot, e.g.sonic jet or so on, It will be reflected in p_rgh, therefore it wont be a sudden crash. Anyhow, small courant number in the order of 0.1 may help too.
Good luck
Ardalan
Ardali is offline   Reply With Quote
Old   July 3, 2020, 03:15
kimy
Thanks a lot. As you said, I already neglected energy euqation. Even though I set maxCo 0.1, the maximum time step is 2e-5 or 2e-6. The totall cells are 260000. How about your time step used in the simulation?
Good luck
Ardalan
Old   July 3, 2020, 03:24
kimy
Thank you. I uploaded my test files and mesh here. Could you please help me to have a look? By the way, the parameters in slurry pipe I used are the following:
pipe diameter 0.1 m (only half)
particle diameter 1e-4 m
Uin=2.5 m/s
alphas=0.2
Old   July 3, 2020, 03:29
kimy
I uploaded the files here without mesh, due to the large size.
Old   July 3, 2020, 03:38
kimy
I saw your previous post and I checked your test case uploaded there. The timestep in your case is 2e-4 s. So you need several days or more to finish one simulation?
Old   July 6, 2020, 10:30
kimy
Nobody is curious about this issue?
Old   July 6, 2020, 11:38
rdbisme's Avatar
Ruben Di Battista
actually.. no. Running the test case in parallel the test would finish in a matter of hours... Why do you say days? Are you running in parallel?
Old   July 7, 2020, 08:27
kimy
Thanks. I did not try parallel but in the end I will do it. I am curious that there is the way to increase the time step.
Old   July 7, 2020, 08:32
rdbisme's Avatar
Ruben Di Battista
With a very basic explanation: The time step of a simulation can't be arbitrarily changed. Based on the time and space schemes you are using, there's a so-called CFL condition that restricts the maximum time step you can achieve. This CFL condition takes also in consideration the cell size: that means if you have a very fine mesh, you're generally gonna have a small time step to keep the numerical scheme stable.
What you can do to increase the time step is to compromise on some aspects:
- Use a coarse mesh
- Use low order numerical schemes that have larger stability regions
- Use implicit time schemes
- Increase the Courant number (that will reduce your stability)
granzer likes this.
Old   July 7, 2020, 08:42
kimy
Hi guys, I met a new problem that the converency issue between the unstrcture mesh created by workbench and structure mesh generated by blockMesh. Why the iteration of P_rg is 1000, which means unconverged, right? Do you habe any suggestion? Thank u.
Old   July 7, 2020, 08:52
kimy
Thanks a lot. I already considered what you mentioned below however, the time step is the samll one. Now I regard that issue as normal one. Really thank u. Gentilissimo!
- Use a coarse mesh
timestep, twophaseeulerfoam
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 5, 2023 23:48
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
