April 7, 2020, 17:44 |
Problem with noCombustion > rhoReactingFoam
Hi Foamers,
It is few months since I have started dealing with OpenFOAM and of course i seldom run into multiple errors that i can usually takle also looking at the threads in this forum. This time i cannot manage to solve my problem. In particular I am working on a problem that is very similar to the tutorial that you find in combustion/reactingFoam/counterFlowFlame2D. I am running the OpenFOAM v1912 version. If i run the simulation as it is, everything works properly, however if i switch off the combustion by simply acting on the combustionProperties file: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | \\ / O peration | Version: v1912 | \\ / A nd | Website: www.openfoam.com | \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object combustionProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // combustionModel noCombustion; active false; noCombustionCoeffs { } // **********************************************************// Code:
Reading/calculating face flux field phi Creating turbulence model. Selecting turbulence model type laminar Selecting laminar stress model Stokes Creating reaction model Selecting combustion model noCombustion Can you help me understanding what is going on? |
August 11, 2020, 13:34 |
Robert Crane
Rep Power: 5 |
did you ever figure this out? I am having the same problem.
August 11, 2020, 15:32 |
Rep Power: 14 |
Try "none" instead of "noCombustion" - that seems to work fine for me.
August 11, 2020, 16:02 |
Robert Crane
Rep Power: 5 |
thank you, that worked for me as well.
nocombustion, reactingfoam |
area does not match neighbour by ... % -- possible face ordering problem | St.Pacholak | OpenFOAM | 10 | February 7, 2024 21:50 |
Heat Transfert, mixing problem | Wazdq | CFX | 8 | November 7, 2016 05:44 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
DNS to Eigenvalue -> Cauchy Problem | RMG | Main CFD Forum | 0 | February 4, 2004 05:50 |
