ACMI rotating zone: which frame is used for fixedValue, noSlip, movingWallVelocity?
Old   September 2, 2020, 03:13
Default ACMI rotating zone: which frame is used for fixedValue, noSlip, movingWallVelocity?
Tobias Kienzler
zommuter is on a distinguished road
I'm simulating a pump with its stator and rotor separated by an cyclicACMI. The rotor mesh is rotating (no MRF). Since the gap is very narrow at some points, I want them to be non-overlapping parts using ACMI's neighbourPatches. Now my question, which boundary conditions should I use where? The stator's walls are fixed and the rotor's ones rotating, obviously.
$FOAM_TUTORIALS/incompressible/pimpleFoam/RAS/oscillatingInletACMI2D (the only cyclicACMI tutorial case I could actually find) declares the blockage as type wall; in blockMeshDict, which makes sense either way. But in 0/U the blockage uses a noSlip condition, whereas all other non-interface walls have a movingWallVelocity of 0. The user guide on that states
Sets the velocity to the desired value for moving walls when employed in moving mesh cases
which is honestly confusing me a bit. The tutorial case seems to imply that velocity is relative to the moving wall, correct? On the other hand, noSlip "sets the patch velocity to (0 0 0)", which sounds very absolute (and identical to fixedValue (0 0 0)?). In the tutorial case I guess it makes sense; while the small box is moving up and down, it slides along fixed walls. So I think noSlip is also the proper choice for the rotor's blockage.
But what about the stator's blockage? That should be a moving wall of the rotor, not a stationary one. And while the rotor zone does rotate I wonder how to state "noSlip, but in the rotating mesh's frame". The boundary condition guide doesn't mention it, but deeper down in the API documentation I found rotatingWallVelocity while writing this post, is that the proper condition to select then?
That's what I'm going to try now anyway, but of course I'd appreciate input from anyone who already did something along this line.
zommuter is offline   Reply With Quote
acmi, movingwallvelocity, noslip, reference frame, rotating mesh
Wrong Unsteady Statistics by Fluent for rotating zone Engineer2k1 FLUENT 5 March 10, 2020 19:43
a small question about rotating frame JinZhiyi SU2 1 May 15, 2014 15:21
question about governing equation in CFX using rotating/non rotating reference frame rystokes CFX 0 January 12, 2010 06:14
Rotating solid zone Rajesh FLUENT 0 May 17, 2008 05:44
Sliding mesh error Karl Kevala FLUENT 4 February 21, 2001 15:52
