I want to find proper solver. (multiphase & heat exchange) |
Munho Kim
Rep Power: 0 ![]() |
Hello! I'm a newb of OF.
i want to find a proper solver that can handle multiphase and heat transfer. What i want to do is shoot hot air into a pipe half full of water. I expect hot air make water to steam. Is it possible?? And is there any solver to handle it? I will appreciate it in advance. |
Joachim Herb
Rep Power: 21 ![]() |
In the ESI version of OpenFOAM there is the solver chtMultiRegionTwoPhaseEulerFoam. But I am not sure, if you can use different gases (air/steam) with it.
See: https://www.openfoam.com/releases/op...nd-physics.php |
Munho Kim
Thank you so much jherb.
i will try to do this solver. if i will success, i will compare the result. Thank you again! |
Nicolas de Revière
Here you have the list and description of OpenFOAM solvers : https://openfoam.com/documentation/u...rd-solvers.php Less exhaustive but easier to use, the simplified decision matrix : https://www.openfoam.com/documentati...s-solvers.html find 2 exctracts pictures of solvers list you should pick in. I you're looking for a simple and robust User Interface (from CAD import to post-treament), think about ESI Visual-CFD ![]() bye nderev |
#5 | |
wanghongjie
Rep Power: 6 ![]() |
0/BASE/T dimensions [0 0 0 1 0 0 0]; internalField uniform 0; boundaryField { SJUERE { type zeroGradient; } SFRONTANDBACK { type empty; } HEAT { type fixedGradient; gradient uniform 50; } BASE_FLUID { type compressible::turbulentTemperatureCoupledBaffleMix ed; value $internalField; Tnbr T; kappaMethod solidThermo; } } TEqn.H { Info<<"10"<<endl; volScalarField& T = thermo->T(); Info<<"11"<<endl; tmp<volScalarField> tcp(thermo->Cp()); const volScalarField& cp = tcp(); Info<<"12"<<endl; const dimensionedScalar Cp1 = thermo->Cp1(); const dimensionedScalar Cp2 = thermo->Cp2(); Info<<"13"<<endl; rhoCp = rho*cp; Info<<"14"<<endl; kappaEff = thermo->kappa() + rho*cp*turbulence.nut()/Prt; Info<<"15"<<endl; const surfaceScalarField rhoCpPhi ( "rhoCpPhi", rhoPhi*(Cp1 - Cp2) + phi*rho2*Cp2 ); Info<<"16"<<endl; Pair<tmp<volScalarField>> vDotAlphal = mixture.mDot(); Info<<"17"<<endl; fvScalarMatrix TEqn ( fvm::ddt(rhoCp, T) + fvm::div(rhoCpPhi, T) - fvm::Sp(fvc::ddt(rhoCp) + fvc::div(rhoCpPhi), T) - fvm::laplacian(kappaEff, T) + mixture.TSource() ); Info<<"18"<<endl; TEqn.relax(); TEqn.solve(mesh.solver(he.select(finalIter))); thermo->correct(); Info<< "min/max(T) = " << min(T).value() << ", " << max(T).value() <<endl; } Error: #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 ? in /lib/x86_64-linux-gnu/libpthread.so.0 #3 Foam::mapDistributeBase::mapDistributeBase(Foam::U List<int> const&, Foam::UList<int> const&) at ??:? #4 Foam::mapDistribute::mapDistribute(Foam::UList<int > const&, Foam::UList<int> const&) at ??:? #5 Foam::mappedPatchBase::calcMapping() const at ??:? #6 Foam::mappedPatchBase::map() const at ??:? #7 void Foam::mappedPatchBase::distribute<double>(Foam::Li st<double>&) const at ??:? #8 Foam::compressible::turbulentTemperatureCoupledBaf fleMixedFvPatchScalarField::updateCoeffs() at ??:? #9 Foam::fvMatrix<double>::fvMatrix(Foam::GeometricFi eld<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) in ~/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/bin/chtConEvaFoam #10 Foam::temperaturePhaseChangeTwoPhaseMixtures::cons tant::TSource() const at ??:? #11 ? in ~/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/bin/chtConEvaFoam #12 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #13 ? in ~/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/bin/chtConEvaFoam Segmentation fault (core dumped) |
PEMFC model with FLUENT | brahimchoice | FLUENT | 22 | April 19, 2020 15:44 |
Multiphase heat transfer | pkladisios | CFX | 8 | June 7, 2016 01:41 |
Immersion Multiphase Heat Transfer | Liquid774 | FLUENT | 0 | June 4, 2012 15:37 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
