Question about the Porosity model using DarcyForchheimer Equation
Like Tree2Likes
  • 1 Post By Chaoran
  • 1 Post By Tobi
Old   September 12, 2020, 00:21
Default Question about the Porosity model using DarcyForchheimer Equation
Chaoran Guan
Chaoran is on a distinguished road
I'm confused about the implementation of the DarcyForchheimer equation in Openfoam. As I found in openfoam wiki https://openfoamwiki.net/index.php/DarcyForchheimer
the source term was like
S_m = - (\mu \bf{D}+\frac{1}{2}\rho tr(\bf{U}\cdot\bf{I})\bf{F})\bf{U}
or
\Delta p = -(\mu \bf{D}_i \bf{u}_i - \frac{1}{2} \bf{F}_i |u_{kk}|u_i)
But when I dig into the source code in DarcyForchheimer.H. I found something like
 forAll(cells, i)
             const label celli = cells[i];
             const label j = this->fieldIndex(i);
             const tensor Cd =
                 mu[celli]*dZones[j] + (rho[celli]*mag(U[celli]))*fZones[j];
             const scalar isoCd = tr(Cd);
             Udiag[celli] += V[celli]*isoCd;
             Usource[celli] -= V[celli]*((Cd - I*isoCd) & U[celli]);
where user defined values of D and f from the fvOptions dictionary are stored in the diagonal elements of the tensor \emph{dZones[j]} and 0.5*f in \emph{fZones[j]}.
I just can't understand the relations between the source code and the above equation. Why use the \emph{isoCd} trace of tensor \emph{Cd} and the term \emph{(Cd - I*isoCd)}.
And I want to implement a source term like
S_m = -(A + B*|\bf{u}|^{0.9})\bf{u}
Can anybody help? Thanks in advance.
vitto likes this.
Chaoran is offline   Reply With Quote
Old   September 29, 2020, 06:33
Tobi's Avatar
Tobias Holzmann
Hi Chaoran, well this is not trivial out of the box but is related to numerical stabilization. What is the Darcy-Forchheimer actually? It is a source term in the momentum equation, right? So putting the source term directly to the source (RHS) does make the system more explicit and as you can see here, we extract some part from the source term to add it implicitly to the matrix (it is actually the trace part).
So what we see is that we do create the source Cd. Then we extract the implicit part and put that to the matrix. However, the explicit part does now have to be modified by removing the already added implicitly part which lead to the (Cd - I*isoCd) term.
However, sure, you can re-implement the following:
             const tensor Cd =
             Usource[celli] -= V[celli]*(Cd  & U[celli]);
but this is 100 % explicit and requires more outer corrections because the source is dependent on the velocity.
Thatīs it. Even without making the mathematicial proof. The explanation abvoe should be fine.
Origami likes this.
Keep foaming,
Tobias Holzmann
Old   September 29, 2020, 20:17
Smile
Chaoran Guan
Hi, Tobias. Your explanations help me out. Really appreciate it.
darcy-forchheimer, fvoptions,momentum source, porosity model
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 16, 2020 23:44
Porosity and the energy equation shock77 OpenFOAM Running, Solving & CFD 11 May 9, 2020 15:52
[swak4Foam] swakExpression not writing to log alexfells OpenFOAM Community Contributions 3 March 16, 2020 18:19
Identification of the porous region in powerLawLopesdaCosta porosity model Tarak OpenFOAM 1 February 11, 2020 16:32
