Velocity gradient that looks like checkerboard
Old   September 26, 2015, 12:57
Default Velocity gradient that looks like checkerboard
J.-H. Wang
f0208secretx is on a distinguished road
I am solving an acoustic problem arises from turbulence. For that I am using pimpleFoam + Spalart-Allmaras DES (OpenFOAM 2.4.0 on RHEL) as suggested by some people when grid resolution is not high enough. I am particularly concerned with the velocity gradient as it will act as a quadrupole source term when acoustic analogy is used.
For the current setup, I have two problems:
1. I couldn't seem to get rid of the "checkerboard" velocity gradient despite the relatively smooth velocity field. Quotation because I don't think they are as bad as the real checkerboard issue. Pictures are attached.
2. There seems to be some artifacts when transitioning from coarser grid to denser grid near the region of interest.
Currently I suspected its the convergence issue, but it could also be the gradient scheme I chose to compute the gradient (cell limited gauss linear 0.8)? I posted my fvSolution/fvScheme and hopefully someone with some experience could point out some obvious errors. Any help is appreciated. Thanks.
fvScheme:
|  \\    /   O peration     | Version:  2.1.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default         backward;
gradSchemes
    default         Gauss linear;
    grad(nuTilda)   cellLimited Gauss linear 0.8;
    grad(U)         cellLimited Gauss linear 0.8;
divSchemes
    div(phi,U)      Gauss LUST unlimitedGrad(U);//Gauss limitedLinear 1
    //div(phi,U)      Gauss linearUpwind unlimitedGrad(U);
    div(phi,k)      Gauss limitedLinear 1;
    div(phi,B)      Gauss limitedLinear 1;
    div(phi,nuTilda) Gauss limitedLinear 1;
    div(B)          Gauss linear;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
    //default         none;
    //div(phi,U)      Gauss linearUpwindV grad(U);
    //div(phi,k)      Gauss upwind;
    //div(phi,omega)  Gauss upwind;
    //div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
    interpolate(U)  linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p;
fvSolution:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    p
       solver PCG;
       preconditioner DIC;
       tolerance 1e-6;
       relTol 0.01;
    pFinal
       solver PCG;
       preconditioner DIC;
       tolerance 1e-8;
       relTol 0;
    U
      solver PBiCG;
      preconditioner DILU;
      tolerance 1e-6;
      relTol 0.1;
    B
      solver PBiCG;
      tolerance 1e-6;
      relTol 0.1;
    "(U|k|epsilon|omega|nuTilda)Final"
      solver PBiCG;
      tolerance 1e-8;
      relTol 0;
PIMPLE
    nOuterCorrectors 2; // 1 leads to a piso algorithm
    nCorrectors     3;
    nNonOrthogonalCorrectors 2;
    pRefCell        0;
    pRefValue       0;
f0208secretx is offline   Reply With Quote
Old   October 14, 2020, 21:04
Stanley John
sjohn2 is on a distinguished road
I know its quite late, but just in case.
did you find why checkerboard pattern happened in first place?
sjohn2 is offline   Reply With Quote
Old   October 15, 2020, 01:12
Arjun
arjun will become famous soon enougharjun will become famous soon enough
The picture attached does not show checkerboarding. What it shows is pressure shoot up due to cell quality.
arjun is offline   Reply With Quote
access to velocity gradient for Lagrangian particles jiejie OpenFOAM 31 December 2, 2016 04:56
[General] Gradient of 2D velocity field eleonora ParaView 0 January 30, 2015 03:42
[swak4Foam] Velocity gradient outlet BC penalisation using groovyBC Hiroshiman OpenFOAM Community Contributions 10 June 11, 2014 16:57
Velocity gradient Stephen FLUENT 0 April 7, 2003 10:29
Velocity gradient Stephen Main CFD Forum 0 April 7, 2003 10:28
