Inlet turbulence for swirling flow
Old   September 28, 2020, 14:01
Default Inlet turbulence for swirling flow
Adhiraj
adhiraj is on a distinguished road
Hello all,
I am using LES (OpenFOAM 2.3.x) to model a flow where swirl is imparted by a set of vanes. I know the mean axial velocity, and can calculate the swirl component at the exit plane of the vanes.
The attached image shows a slice through the domain. The flow is vertically upward in this picture, and the inlet to the domain is at z = -40 mm. This is also the swirl vane exit plane.
At the inlet I can prescribe the mean axial velocity (U_{z}), and the mean swirl velocity (obtained from U_{x} and U_{y}).
The problem is that I cannot figure out how to prescribe velocity fluctuations at inlet.
For a case with no swirl I used a mapped boundary condition to recycle velocity from a plane downstream of the inlet, and fed it back to the inlet. That worked for the non-swirling cases but not for this case.
Can someone suggest a way to impart turbulent fluctuations in this case?
Thanks.
adhiraj is offline   Reply With Quote
how to set URANS turbulence model in unsteady flow simulation TimLiu OpenFOAM Pre-Processing 0 April 25, 2017 08:52
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 14:18
Meaning of turbulence terms when flow direction is reversed at mass flow inlet zackufairu FLUENT 6 November 6, 2014 15:35
How to define a fixed velocity for a given mass flow rate on inlet mqasimali FLUENT 2 April 12, 2013 17:24
steam flow in a pipe driven by a pressure gradient between inlet and outlet SalvoCalvo COMSOL 0 March 11, 2010 06:52
