Pimple failing without any warning or any abnormal |
October 2, 2020, 01:39 |
Stanley John
Rep Power: 7 |
PIMPLE ids failinfg without any warning, not sure what is the reason, when I re run the case it fails at a later time, any hints is it the GAMG solver?
PHP Code:
October 3, 2020, 10:36 |
Michael Alletto
Looks like some mpi error. Did you try to run it on one node
October 4, 2020, 20:24 |
Stanley John
Rep Power: 7 |
Unfortunately running in serial is not an option, takes for ever.
I instead ran the pressure with PBiCGStab and this problem went away. Can you check if my GAMG settings are right. This problem always seem to arise while solving on the coarsest grid PHP Code:
October 5, 2020, 03:16 |
Michael Alletto
I'm not an expert settings of the gamg solver. I use the one of the motorbike tutorial. Playing around with the parameters and seeing what happens is also an option
foamToTecplot360 | thomasduerr | OpenFOAM Post-Processing | 121 | June 11, 2021 10:05 |
Caffa 3D code | Waliur Rahman | Main CFD Forum | 0 | May 29, 2018 00:53 |
[swak4Foam] installation problem with version 0.2.3 | Claudio87 | OpenFOAM Community Contributions | 9 | May 8, 2013 10:20 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
