Simulating an oscillating wall: uniformFixedValue or movingWallVelocity |
January 14, 2017, 12:07 |
Pete Bachant
Rep Power: 14 |
I am trying to simulate an oscillating wall boundary condition without a moving mesh, so I'm currently using uniformFixedValue BC with a sine and zero offset. However, computing force on the wall is giving a strange result: it never drops below the value it had at t=0, even though the velocity becomes negative. Should I be using a movingWallVelocity BC? Is it even possible to define a moving wall with a sine oscillation?
Note that in my case, it's mostly a normal velocity, like a piston, rather than a shearing flat plate type case. |
November 11, 2020, 05:07 |
BC uniformFixedValue for oscilating
Rmc
Rep Power: 5 |
hello i am looking for BC for uniformFixedValue for an oscillating wall as you specified.
please reply. |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
rotating wall inside of an MRF zone - fixedValue or movingWallvelocity? | evrikon | OpenFOAM Running, Solving & CFD | 3 | April 30, 2015 03:51 |
Simulating oscillating beam | shuiit | FLUENT | 0 | September 1, 2014 03:48 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
