OpenFOAM simulation stops with no error when increasing mesh element density |
November 26, 2020, 17:02 |
Dan Padrao
Rep Power: 6 |
I've got a curious error in my simulation. The simulation will stop running at an early time step and exit without giving an error or explaining why. I began running this in parallel and the only erroneous line displayed was: Code:
[58] #0 Foam::error::printStack(Foam::Ostream&) This error only occurred when I increased my mesh element density from 175x315x42 to 200x360x48. The simulation worked for the former but not the latter which leads me to believe that it is a meshing problem. But when I use checkMesh it says that it only failed one test and I believe it was because of concave faces/cells. I've attached my case below (some files, like the stl file, were removed due to the max file size) so if anyone could give me any indication as to why this is happening I would greatly appreciate it. Thanks, Dan |
OpenFOAM - mixing tank simulation using dynamic mesh | foamF | OpenFOAM | 3 | February 9, 2021 15:43 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
