Is ignoring the Uz component in axisymmetric simulations safe? |
December 12, 2020, 07:23 |
Hüseyin Can Önel
Rep Power: 7 |
I am running simpleFoam with wall-resolved kOmegaSSt on an axisymmetric geometry and Uz residual won't go below 1e-4 while other variables are way below 1e-5. To be exact: Code:
Time = 2612 smoothSolver: Solving for Ux, Initial residual = 1.47806e-05, Final residual = 4.27788e-06, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.000255141, Final residual = 2.18455e-05, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.00580407, Final residual = 0.000204739, No Iterations 2 GAMG: Solving for p, Initial residual = 7.11716e-05, Final residual = 6.89229e-06, No Iterations 15 time step continuity errors : sum local = 8.9928e-07, global = 1.83346e-08, cumulative = -0.0018131 smoothSolver: Solving for omega, Initial residual = 1.03051e-05, Final residual = 3.00373e-06, No Iterations 1 smoothSolver: Solving for k, Initial residual = 5.23285e-05, Final residual = 4.50814e-06, No Iterations 2 ExecutionTime = 815.15 s ClockTime = 817 s I have noticed that in planar (2D) geometries (with empty BCs) the Uz component is not calculated at all, whereas in axisymmetric geometries (with wedge BCs) the Uz component is calculated. First, this did not make sense to me, but if you consider a swirling flow with axisymmetric azimuthal component everywhere, it would still be an axisymmetric flow in polar coordinates. Am I wrong? In that case, the Uz component (azimuthal component actually) should converge. On the other hand, I do not think that OpenFOAM switches to polar coordinates in an axisymmetric simulation; it just carries out 3D computations with special BC treatments (right?). So my question is, is setting the residual control for Uz to a large value completely safe in axisymmetric geometries in OpenFOAM? Thanks in advance, Huseyin |
ANSYS Workbench on "Uncertified" Linux Distros | hsr | CFX | 289 | April 20, 2023 09:23 |
Axisymmetric Vs. 3D issue? | tareqkh | OpenFOAM Running, Solving & CFD | 1 | May 29, 2017 18:41 |
W component of the momentum equation and its validity in 2D simulations | JuPa | CFX | 2 | April 10, 2014 04:16 |
[Commercial meshers] 2D axisymmetric simulation starting with a 2D fluent msh file.... How ? | vishalsacharya | OpenFOAM Meshing & Mesh Conversion | 0 | November 17, 2011 00:29 |
Axisymmetric Simulations | CFDtoy | FLUENT | 1 | December 1, 2006 07:57 |
