icoFoam crashing due to high courant numbers
Old   January 20, 2021, 08:38
Default icoFoam crashing due to high courant numbers
Thomas44 is on a distinguished road
Hi everyone,
I have a problem with icoFoam crashing due to very high courant numbers.
Time = 0.0062
Courant Number mean: 1.70314 max: 1.70807
smoothSolver:  Solving for Ux, Initial residual = 0.321492, Final residual = 1.39023e+44, No Iterations 1000
smoothSolver:  Solving for Uy, Initial residual = 0.321716, Final residual = 3.3051e+44, No Iterations 1000
smoothSolver:  Solving for Uz, Initial residual = 0.483206, Final residual = 1.01409e+46, No Iterations 1000
DICPCG:  Solving for p, Initial residual = 1, Final residual = 0.045319, No Iterations 27
DICPCG:  Solving for p, Initial residual = 0.0597692, Final residual = 0.00264667, No Iterations 15
DICPCG:  Solving for p, Initial residual = 0.0159539, Final residual = 0.000757184, No Iterations 22
time step continuity errors : sum local = 3.0971e+41, global = 2.73201e+39, cumulative = 2.73201e+39
DICPCG:  Solving for p, Initial residual = 0.443715, Final residual = 0.0178101, No Iterations 10
DICPCG:  Solving for p, Initial residual = 0.0497066, Final residual = 0.0021327, No Iterations 31
DICPCG:  Solving for p, Initial residual = 0.0169567, Final residual = 8.78265e-07, No Iterations 54
time step continuity errors : sum local = 3.20666e+38, global = -6.63929e+36, cumulative = 2.72537e+39
ExecutionTime = 9.1 s  ClockTime = 9 s
Time = 0.0063
Courant Number mean: 4.11596e+44 max: 1.69555e+47
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in /lib/x86_64-linux-gnu/libpthread.so.0
#3  Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:?
#4  Foam::symGaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
#5  Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6  Foam::fvMatrix<Foam::Vector<double> >::solveSegregated(Foam::dictionary const&) at ??:?
#7  Foam::fvMatrix<Foam::Vector<double> >::solveSegregatedOrCoupled(Foam::dictionary const&) at ??:?
#8  Foam::fvMesh::solve(Foam::fvMatrix<Foam::Vector<double> >&, Foam::dictionary const&) const at ??:?
#9  ? in /opt/OpenFOAM/OpenFOAM-v2012/platforms/linux64GccDPInt32Opt/bin/icoFoam
#10  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
#11  ? in /opt/OpenFOAM/OpenFOAM-v2012/platforms/linux64GccDPInt32Opt/bin/icoFoam
The goal is to simulate the flow of water through a simple cylinder with fixed pressure values of 2.4 bar at the inlet and 1 bar at the outlet.
I'm new to OpenFoam and have set-up the simulation case to my best knowledge. The attached files should include everything needed to run the case including the blockMeshDict.
It would be nice if someone could give me a hint what I made wrong and what parameter I have to change to achieve my goal.
Thanks in advance
Thomas
Thomas44 is offline   Reply With Quote
Old   January 21, 2021, 03:42
shock77 is on a distinguished road
I think you cant use fixedValue for the static pressure at both ends, because there are infinity solutions. Maybe thats the reason why your velocity becomes very big and thus the Courant number. I am quite sure its due to ill posed BCs.
Try using totalPressure with pressureInletOutletVelocity for U at one end and fixedPressure at the other end with zeroGradient for U.
shock77 is offline   Reply With Quote
Old   January 21, 2021, 04:22
anonymous
simrego is on a distinguished road
Hi!
You are using icoFoam and already exceeded Co = 1 before the crash. You can't do that with the PISO algorithm.
Keep the Co bellow 1 or bellow 0.8 so you will be in safe.
Or change to pimpleFoam and you can exceed Co = 1 with inner loops.
simrego is offline   Reply With Quote
Old   January 21, 2021, 09:59
So p and U would look like this?
inlet
    type    totalPressure;
    p0      uniform 240;
outlet
    type    fixedValue;
    value   uniform 100;
inlet
    type    pressureInletOutletVelocity;
    value   uniform (0 0 0);
outlet
    type    zeroGradient;
Old   January 21, 2021, 10:17
I suppose you are running an incompressible case, so yes. For your furhter information on the totalPressure BC:
https://cpp.openfoam.org/v3/a02627.html
Old   January 26, 2021, 10:37
With the initial conditions you proposed I get the same Courant number problem, but you are right that the boundary conditions are the reason for it.
I ran a case with pressures of fixedValue at the inlet and zeroGradiend at the outlet and the simulation was successful. Not sure how to proceed now.
Old   January 26, 2021, 11:01
anonymous
Before you dig deeper into that, drop your mesh to the trash and create a correct one. This is bad. Really bad.
File Type: jpg Screenshot from 2021-01-26 17-00-58.jpg (50.1 KB, 32 views)
courant, cylinder, icofoam
Actual Courant Numbers much greater than maxCo in interFoam with Local Time Stepping Ship Designer OpenFOAM Running, Solving & CFD 16 August 5, 2022 11:08
Simulation stops with high courant number Victor3 OpenFOAM Running, Solving & CFD 2 January 29, 2020 11:49
high Courant number m5m5kh OpenFOAM Running, Solving & CFD 1 July 9, 2013 07:48
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
pls help fluctuating residuals due to courant no sagar CFX 3 March 28, 2006 01:10
