PotentialFoam configuration for rhoPimpleFoam
Old   February 24, 2021, 05:25
Default PotentialFoam configuration for rhoPimpleFoam
OisinOC is on a distinguished road
I am trying to use potentialFoam to initialise the flow for a rhoPimpleFoam simulation but I get the following error.
--> FOAM FATAL ERROR:
    request for volScalarField thermo:psi from objectRegistry region0 failed
    available objects of type volScalarField are
4
div(((sqr(U)|(magSqr(U)+(1e-015*average(magSqr(U)))))&convection(phi,U)))
Phi
magSqr(U)
p
From reading other posts I think it relates to the thermosi present in waveTransmissive boundary from the p initial conditions file and that I need to use one of the four options it has suggested but I'm not sure how to implement it and be confident I've not impacted the rhoPimpleFoam model. I started with the LES Pitzdaily tutorial for rhoPimpleFoam in case that is relevant.
Could anyone explain how to fix this potentialFoam error? Or do I need to create a separate model to initialise the flow and then copy the solutions latest time files into the 0 directory for the rhoPimpleFoam?
|  \\    /   O peration     | Version:  5                                     |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 1e5;
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            waveTransmissive;
        psi             thermo:psi;
        gamma           1.3;
        fieldInf        1e5;
        lInf            0.3;
        value           $internalField;
    wall
        type            zeroGradient;
    defaultFaces
        type        zeroGradient;
OisinOC is offline   Reply With Quote
CFD workstation configuration calling for help 2 Freewill1 Hardware 6 July 8, 2020 21:17
[OpenFOAM.org] Cannot open configuration file mpicc-wrapper-data.txt mpicc: Not found wenjuny OpenFOAM Installation 0 November 25, 2019 09:01
OpenFOAM v4.1 - farfield bc potentialFoam jeytsav OpenFOAM Running, Solving & CFD 0 November 23, 2016 09:06
potentialFoam doesnt start?! Sway OpenFOAM Running, Solving & CFD 0 July 2, 2015 07:48
Multiple Configuration Simulation Tristan CFX 0 November 13, 2009 23:01
