How to delete the same time folder in different processors folder
Like Tree11Likes
  • 2 Post By shock77
  • 1 Post By chandra shekhar pant
  • 5 Post By AndreasPe
  • 1 Post By olesen
  • 1 Post By AndreasPe
Old   March 2, 2021, 04:44
Default How to delete the same time folder in different processors folder
chandra shekhar pant is on a distinguished road
Hello All,
I am running a OpenFOAM case in 50 processors, now I wanted to delete a time folder (say 0.5) from all the folders to save the memory. Earlier for less number of processors I used a very common/basic command to delete that specific file 0.5 by running the following command for each processor
rm -r 0.5
But now since the number of processors are larger (50), so it would be more time consuming and less effective to use this naive way. Could anyone please suggest a better way of doing this ? Any suggestion/comment will be a great help. Thanks in advance.
chandra shekhar pant is offline   Reply With Quote
Old   March 2, 2021, 05:34
shock77 is on a distinguished road
rm -r processor*/0.05
shock77 is offline   Reply With Quote
Old   March 2, 2021, 07:00
Great! Thanks a lot shock77 for your prompt reply and help.
shock77 likes this.
Old   March 3, 2021, 00:40
Andreas P.
AndreasPe is on a distinguished road
In newer versions of OpenFOAM (i used it with version 6) you can also use the foamListTimes utility and thus can delete a time range:
foamListTimes -rm -processor -time "xxxx:xxxx"
for example
foamListTimes -rm -processor -time "0.1:0.5"
will delete all time folders from time 0.1 to time 0.5 in the processor folders.
See also https://www.openfoam.com/documentati...ListTimes.html
AndreasPe is offline   Reply With Quote
Old   March 3, 2021, 01:11
Hello AndreasPe, that's indeed very useful. I am using OpenFOAM v1906, tried for this version, and it worked, great, thanks a lot
Old   March 3, 2021, 14:12
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
This indeed the preferred way to clean out processor time directories. It's been there since OpenFOAM 1.5 or 1.6 (ie, not so terribly recent).
olesen is offline   Reply With Quote
Old   May 1, 2021, 11:53
Thanks a lot all for your kind help. In the continuation of this post, I have re--simulated a case from time =0.208 to time =0.21. Now I have a previous case (from time =0 to time = 0.21) in some server and I had simulated this case (from time = 0.208 to time = 0.21) in another server. For both the cases I have folders ranging from processors0 to processors179 (since I ran the case using 180 processors). I wanted to copy the newly created time folder of time =0.209 and time =0.21 to the previous case (from time =0 to time =0.208). Is there any smart way of coping the different time folders to the specific folders ranging from processors0 to 180? Sorry for confusing you with so many terminologies. Thanks in advance.
Old   May 3, 2021, 01:40
Andreas P.
Just use reconstructPar on the one server with the re-simulated result, then copy the reconstructed time folder to the other server, delete the "wrong" time folders there as described above and then run "decomposePar -fields" to decompose the reconstructed time folder again on this server.
Old   May 3, 2021, 01:45
Hi AndreasPe,
Thanks a lot for your help, I think I understood your post 99% , what I don't understand is "delete the "wrong" time folders there as described above". What you want me to delete ? Many thanks again for your help, its indeed very helpful.
Old   May 3, 2021, 01:51
Andreas P.
Maybe you confused me and you can just ignore this part...
It is not clear, if the previous case has time folders 0.208 to 0.21 in the processor folders or not. You state two different things here:
If the "previous case" has time folders from 0.209 to 0.21, then you need to delete them before you can copy them from the new case. If not, you can just copy them...
Old   May 3, 2021, 01:54
Thanks a lot, yes I am pretty sure that my post was not so clear, apologies for that. Many thanks again for your time and consistent help.
laplacianFoam with source term Herwig OpenFOAM Running, Solving & CFD 17 November 19, 2019 13:47
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 05:49
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 02:34
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
