interFoam with scalar transport in single phase
Like Tree16Likes
  • 10 Post By randolph
  • 1 Post By Sud_fluid
  • 1 Post By 37269
  • 1 Post By randolph
  • 2 Post By JVNR
Old   March 3, 2021, 08:50
Default interFoam with scalar transport in single phase
Reviewer #2
randolph is on a distinguished road
Hi everyone,
I am interested in simulating a scalar transport within the primary phase (i.e., water) in the interFoam.
I follow the approach of phaseScalarTransport (https://github.com/OpenFOAM/OpenFOAM...larTransport.H) and successfully added a scalar transport to the primary phase with MULES compressed flux (i.e., alphaPhiUn).
    fvScalarMatrix YEqn
          fvm::ddt(Y)
        + fvm::div(alphaPhiUn, Y)
        - fvm::laplacian(Deff, Y)
        alpha1*fvOptions(Y)
    YEqn.relax();
    fvOptions.constrain(YEqn);
    YEqn.solve();
The code runs well and as expected the scalar is transported only within the water phase. When the water surface arises, the scalar will arise too. However, when the water surface falls, the part of the scalar will "stuck" above the surface (see attachment). I would like to have scalar fall as the water falls. Could you please shed some light on this issue?
Thanks,
Rdf
File Type: jpg Screenshot from 2021-03-03 08-47-16.jpg (43.1 KB, 202 views)
randolph is offline   Reply With Quote
Old   March 5, 2021, 14:52
Reviewer #2
Okay. I think I figured it out. I will post my findings here for future reference. There are several post concerns about this issue and provide valuable information.
InterFoam: Add an equation to only one phase
interFoam with transport: add a transport equation to only one phase
Numerical problem in species Transport in InterFoam at the interface
interFoam + a scalar transport equation
New phaseScalarTransport function object for a single phase in interFoam
In summary, the simplest way (at this moment) to simulate a scalar transport in a single phase (e.g., water) with interFoam is using the "phaseScalarTransport" utility from the OpenFOAM 7 or 8 (org version). The field alphaS.water = alpha.water * S.water should be used as the results, not the scalar itself (S.water). This is because the continuity equation is calculated for alphaS.water, as shown in the following code. If one looks at the S.water field, the scalar itself will be dispersed into the other phase. This is not a bug.
I use the dambreak as a testing case and found the mass of alphaS.water is generally conserved with an error of less than 1% while the mass of the scalar itself (S.water) will have an error range from 100% to 400%.
             fvScalarMatrix fieldEqn
                 fvm::ddt(alpha, s_)
               + fvm::div(alphaPhi, s_, divScheme)
               - fvm::laplacian
                     fvc::interpolate(alpha)*fvc::interpolate(D),
                     s_,
                     laplacianScheme
                 fvOptions_(alpha, s_)
               - fvm::ddt(residualAlpha_, s_)
               + fvc::ddt(residualAlpha_, s_)
             fieldEqn.relax(relaxCoeff);
             fvOptions_.constrain(fieldEqn);
             fieldEqn.solve(schemesField_);
In the ESI-OpenFOAM, although there is a phase option in the "scalarTransport" utility and they even provide tutorials (e.g, angledDuct, waterChannel), it does not seems that phase constrained transport is implemented at all. In these tutorials, the scalars only diffusive but not convective, as observed in this post (Foam::error::printStack(Foam::Ostream&) with interFoam -parallel). This is likely because the default option for phasePhiCompressed, alphaPhiUn is zero. Although alphaPhiUn is created in the interFoam, the interFoam solver does not pass a value to alphaPhiUn. This seems quite odd to me and please correct me if I am wrong.
There is a method suggested for convecting the scalar in the "scalarTransport" utility of ESI OpenFOAM. Post (Foam::error::printStack(Foam::Ostream&) with interFoam -parallel) suggest that defined the "alphaPhi0.water" for the "phasePhiCompressed". However, after some tests, this method will let some scalar stuck in the air. The "scalarTransport" utility of ESI OpenFOAM tries to conserve the mass for s.water instead of alphaS.water, as shown in the following code.
        tmp<surfaceScalarField> tTPhiUD;
        for (label i = 0; i <= nCorr_; i++)
            fvScalarMatrix sEqn
                fvm::ddt(s)
              + fvm::div(limitedPhiAlpha, s, divScheme)
              - fvm::laplacian(D, s, laplacianScheme)
                alpha*fvOptions_(s)
            sEqn.relax(relaxCoeff);
            fvOptions_.constrain(sEqn);
            sEqn.solve(mesh_.solverDict(schemesField_));
            tTPhiUD = sEqn.flux();
I hope this information helps,
Rdf
Old   May 26, 2021, 07:34
Sudarshan
Sud_fluid is on a distinguished road
I'm also trying to simulate a case (similar to sand in water + air) however I do not understand how to implement the phaseTransportFoam (in particular could you please explain what you meant by interfoam + phaseTransportFoam).
I tried to implement this in the dambreak case. In the controlDict, file I included the following lines before the end.
phaseScalarTransport1
type phaseScalarTransport;
libs ("libsolverFunctionObjects.so");
field s.water;
p p_rgh;
phaseScalarTransport2
field alpha.water * s.water;
p p_rgh;
Then I run the command "interfoam" which ends well but when I enter the command "phaseTransportFoam" it is not found. Could you please tell the steps clearly on how to implement phaseTransportFoam.
Thanks.
Sudarshan.
                 fvm::ddt(alpha, s_)
               - fvm::laplacian
                     s_,
                     laplacianScheme
            fvScalarMatrix sEqn
                fvm::ddt(s)
                alpha*fvOptions_(s)
Rdf
raj kumar saini likes this.
Sud_fluid is offline   Reply With Quote
Old   July 13, 2021, 08:04
37269 is on a distinguished road
It looks like they are working on a fix for this in the ESI-version:
https://develop.openfoam.com/Develop.../-/issues/2053
scleakey likes this.
37269 is offline   Reply With Quote
Old   July 13, 2021, 08:33
Reviewer #2
In the case of fox may encounter this issue. Here is one of my juggling by integrating the "phaseScalarTransport" (org version) with ESI. https://github.com/Rdfing/interAdsFoam
Thanks,
Rdf
Old   September 23, 2021, 03:12
Shengjie Lu
hhu_lulu is on a distinguished road
Hi, randolph.
Your comment is of great help in imposing phaseScalarTransport.However, I'm still confused about its usage.
For instance, what do you mean by 'The field alphaS.water = alpha.water * S.water should be used'? Should I specify a new variable named alphaS.water?
I post part of my functions in controlDict file below(interFoam), could you help checking its correctness? Thank you in advance!
functions
alpha alpha.water;
p p_rgh;
writeAlphaField true;
nCorr 1;
resetOnStartUp false;
writeControl outputTime; // write scalar field results
writeInterval 20;
// D 0.001; //difussion coefficient
// nut nut; //name of field to use as diffusivity, default = 'none'
// alphaDt 2;
// schemesField U; //name of field to use when looking up schemes from fvSchemes
bounded01 true;
hhu_lulu is offline   Reply With Quote
Old   October 4, 2021, 20:52
Reviewer #2
Originally Posted by hhu_lulu View Post
Hi, randolph.
functions
alpha alpha.water;
p p_rgh;
nCorr 1;
writeInterval 20;
// alphaDt 2;
bounded01 true;
Shengjie,
You can just use phaseScalarTransport as explained in the header file (https://cpp.openfoam.org/v7/classFoa...Transport.html). alphaS.water will be the field for postprocessing.
Thanks,
Rdf
hhu_lulu likes this.
Old   November 2, 2021, 22:25
foamF is on a distinguished road
Thanks Randolph for explaining phaseScalarTransport.
I'm new to this function object. It looks your conclusion is alphaS.water is the scalar retained in water phase, and should be used for processing.
I wonder why S.water is present? Is it involved in the scalar transport equation? What's it's physical meaning and under what situation it should be used in processing?
Looking forward to your reply!
foamF is offline   Reply With Quote
Old   November 17, 2021, 18:51
Reviewer #2
This is not the exact reason why alphaS.water should be used. The alphaS.water should be used is because (i) "the continuity equation is calculated for alphaS.water" in the phaseScalarTransport as illustrated in my previous post and (ii) ad-hoc flux correction method implemented in phaseScalarTransport (OpenFOAM 7 or 8 [org version]).
In the ESI-OpenFOAM (e.g., v1912) formulation (i.e., phase option in the "scalarTransport" utility), the mass of the scalar will not be conserved even if alphaS.water is used for the processing.
The way that phaseScalarTransport formulates the phase-constrained scalar transport for interFoam is very similar to how the scalar transport handled in a typical dispersed multiphase flow simulation. The only added effort is on flux correction routine, which is also very similar to the (momentum) flux correction in a typical N-S solver (if my memory serves).
Thanks,
Rdf
Old   January 10, 2022, 00:50
Thomas Sprich
Swift is on a distinguished road
Hi Randolph,
I have read your posts with interest because I am attempting to model the scalar transport between phases, whereas you are interested in the scalar transport limited to a single phase.
I thought I would share my method with you and am interested in your comments. I am sure my approach would work in your case as well.
In my approach, I search through the mesh and compare the values of alpha. If alpha is between 0.05 and 0.95, then I set the diffusivity to a high value and if outside these bounds I set it to 0. This basically meant I have a diffusivity field for which I can solve the scalar transport equation. I actually took the scalar equation directly from scalarTransportFoam.
To make this work for your case, all that would be required would be to set a high diffusivity for the phase that you want and set diffusivity everywhere else to zero.
I created a test case based on the dam break case. I was particularly looking for the problem you identified in your first post, i.e. that the scalar was trapped in the one phase. For my approach, I do not seem to have this problem.
I was then interested in your evaluation of the continuity of the scalar. How did you do this so I can verify for myself with my approach? Anyway, seeing as for interFoam, both phases share the velocity field and the scalar equation comes straight from scalarTransportFoam, I can't imagine there would be continuity issues. Maybe I'm being niave though... Let me know your thoughts.
I've put the code as it is so far on github as well as a test case for you to evaluate. I compiled in on the 2106 ESI version. Here is the link to it:
It is a work in progress, so it may not be as well documented as it could be. Let me know if you have any questions.
My intention is to extend the code and make the diffusivity at the interface dependent on the turbulence as well as alpha and finally to have a maximum limit for the scalar in the phases. In this case, even if there is a difference in value between two cells, but one cell has reached its limit, no more scalar will be diffused across the faces. This is analogous to oxygen transfer of air to water. Air can have 23% O2, whereas the maximum concentration of O2 in water is about 8.5%
I'd appreciate your (or anyone else's) thoughts and comments on my approach.
Thanks,
Thomas
Swift is offline   Reply With Quote
Old   May 24, 2022, 14:29
JVNR is on a distinguished road
Hi everyone! I'm on the brink of a nervous breakdown and about to torch my pc.
Hopefully some of you can give me a hand.
I'm trying to determine the mixing time of a fermenter (stirred vessel with water and bubbles)
To do so I was hoping to use phaseScalarTransport on twoPhaseEulerFoam. Inject some known quatity of scalar S (topoSet) and probe some points in paraview to do the post processing.
The simulation runs normally but no s.water file is created in each of the timesteps. When looking at the log file I see that no calculations are done for the scalar.
Here what I consider the relevant parts of my code:
Regarding boundary conditions the scalar has zerogrdient everywhere since it's being generated by the injectionRateSuSp
In controlDict I put the following (based on https://cpp.openfoam.org/v7/classFoa...ransport.html)
functions
 s
    field           s.water;
    alphaPhi        alphaRhoPhi.water;
    rho             thermo:rho.water;
    resetOnStartUp  no;
    fvOptions
            s
                type            scalarSemiImplicitSource;
                timeStart       0;
                duration        1;
                active          true;
                selectionMode   cellSet;
                cellSet         tracer;
                volumeMode      absolute;
                injectionRateSuSp
                    s.water     (10 0); // kg/s
Additionally I added my fvScheme and my fvSolution
fvSchemes
    div(phi,s.water)     Gauss linearUpwind grad(s.water);
fvSolution
    "s.*"
        solver          PBiCGStab;
        preconditioner  DILU;
        tolerance       1e-08;
        relTol          0;
        minIter	     1;
Can anyone help me? I'm really struggling here.
sadra2003 and finn_amann like this.
JVNR is offline   Reply With Quote
Old   June 20, 2022, 06:35
Smile phaseScalarTransport
  #12
sadra mahmoudi
sadra2003 is on a distinguished road
Hello dear JVNR,
I am also simulating a single bubble moving in a solution of sugar and water. In order to solve the transport of sugar in one phase, I am trying to use phaseScalarTransport. My problem is:
I dont know how exactly should I implement phaseScalarTransport in the interFoam. I would be more than happy if you give me some tips for implementation.
Best regards,
Sadra
functions
 s
    field           s.water;
    resetOnStartUp  no;
    fvOptions
            s
                timeStart       0;
                duration        1;
                active          true;
                cellSet         tracer;
                injectionRateSuSp
fvSchemes
fvSolution
    "s.*"
        solver          PBiCGStab;
        tolerance       1e-08;
        relTol          0;
        minIter	     1;
sadra2003 is offline   Reply With Quote
Old   June 21, 2022, 11:26
finn_amann is on a distinguished road
Hey JVNR,
you probably already solved your problem, but I'll try to help you anyway.
Make sure you have a s.water file in your /0.
I'm pretty sure your fvSchemes is not correct and that you must add a div scheme for alphaPhi.water, s.water, e.g.:
fvSchemes
div(alphaPhi.water, s.water) Gauss linear
Since your alphaPhi is set as alphaRhoPhi in your controlDict, you might have to change it in the example above.
When you start the simulation, abort it immediately and check the beginning of the log in your terminal. For me, the rest of the simulation is running well, too, even if phaseScalarTransport is crashing due to missing entries or something similar. However, the beginning of the log always said something about what's wrong with phaseScalarTransport.
I got a question of my own as well:
Did anybody manage to simulate a constant injection of a concentration in the water phase through a boundary condition? I'm injecting a concetration into an already steady state from a boundary that is fully submerged in alpha.water=1. I've tried InletOutlet, but the simulation crashes after a few time steps the concentration explodes all over the domain. The mesh is rather coarse, so I can quickly test it on my laptop, but I'm not sure if that plays an important role here. Any help or tips would be appreciated.
Best regards
Finn
finn_amann is offline   Reply With Quote
Old   June 22, 2022, 04:12
Smile PhaseScalarTransport
  #14
sadra mahmoudi
Dear Finn,
I would be thankful if you give me a hand.
I am working on single bubble behavior in a solution of sugar and water with InterFoam. In order not to solve the concentration equation inside the bubble, I decided to use PhaseScalarTransport. Since a month ago, I am really struggling to implement it.
I would be appreciative if you have a look at my case to see whether something is wrong.
Best regards,
Sadra
Originally Posted by finn_amann View Post
Hey JVNR,
fvSchemes
Best regards
Finn
Old   June 22, 2022, 10:26
Hey Sadra,
unfortunately I really don't know much about neither OpenFOAM nor phaseScalarTransport. But looking at your controlDict, I think you need something like
functions {
    s {
      functionObjectLibs  ("libsolverFunctionObjects.so");
      enabled             true;
      p                   p_rgh;
      field               s.water; // name of your field, e.g. s.water
      // nCorr               1;
      D                   0.001;
      schemeField         U;
      log                 yes;
I also think that you have to set s.water in your setFieldsDict. I don't know what s_ is supposed to be in your file. Your transported scalar is s.water, I think.
I hope that helps you. All my simulations are not working anyway and explode after a few time steps, so I'm not really much of a help to you, I guess.
Best regards
Finn
Old   June 24, 2022, 04:52
Default phaseScalarTransport
  #16
sadra mahmoudi
Hi Finn,
Thanks a lot for your guidance. I really appreciate it. The problem was resolved and I can simulate it properly. Although I still have some other problems.
As you know, when someone use phaseScalarTransport, the final result (distribution of concentration in the primary phase) will be printed in a variable called "alphaS.water" in the paraview. In my base solver (InterFoam), I would like to make the density dependant on the concentration (alphaS.water). In fact, I would need something like:
rho=alpha2*mu2 + alpha1*(0.0008*exp(0.0486*alphaS.water))
in which alpha2 is air and alpha1 is water.
Now, the problem is, in spite of defining alphaS.water in the creatFiled of solver, the solver can not be compiled because it does not recongnise alphaS.water.
I would be thankful if anybody give me a hand.
Best regards,
Sadra
Hey Sadra,
functions {
    s {
      enabled             true;
      p                   p_rgh;
      // nCorr               1;
      D                   0.001;
      schemeField         U;
      log                 yes;
Best regards
Finn
Old   July 12, 2022, 11:26
Hello people!
I wanted to ask what kind of schemes and solution settings you guys have been using for your simulations in this context so far? Have you been using rectangular or triangular cells and how succesful were youg with either one?
Old   July 13, 2022, 05:53
Smile
  #18
sadra mahmoudi
Hi finn_amann,
This is my fvScheme:
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
divSchemes
//div(rhoPhi,U) Gauss limitedLinear 1;
div(rhoPhi,U) Gauss linear 1;
div(phi,alpha) Gauss linear 1;
div(phirb,alpha) Gauss interfaceCompression; //Gauss linear;
div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
div(phi,C) Gauss limitedLinear 1;
div((phi*interpolate(alpha.air)),C) Gauss upwind 1;
div(rhoPhi,C) Gauss upwind 1;
div((rhoPhi*interpolate(alpha.air)),C) Gauss upwind;
div(((100*dc)*grad(alpha.air))) Gauss linear 1;
div((interpolate((1-alpha.air))*phi),C) Gauss linear 1;
div(alphaPhi,C) Gauss linear 1;
div(alphaPhi,C_) Gauss linear 1;
div(alphaPhi.water,s.water) Gauss linear 1;
div(alphaPhi.water,alpha.water) Gauss linear 1;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
and this one is my fv solution:
| \\ / O peration | Version: v2006 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
"alpha.*.*"
interfaceMethod "isoAdvector";
isoFaceTol 1e-6;
surfCellTol 1e-6;
snapTol 1e-12;
nAlphaBounds 3;
clip true;
reconstructionScheme plicRDF;
nAlphaCorr 2;
nAlphaSubCycles 1;
cAlpha 1;
MULESCorr yes;
nLimiterIter 3;
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-8;
relTol 0;
"s.*"
solver PBiCGStab;
tolerance 1e-08;
relTol 0;
minIter 1;
"pcorr.*"
solver PCG;
preconditioner
preconditioner GAMG;
tolerance 1e-05;
relTol 0;
smoother DICGaussSeidel;
tolerance 1e-05;
relTol 0;
maxIter 100;
p_rgh
solver GAMG;
tolerance 1e-08;
relTol 0.001;
smoother DIC;
p_rghFinal
solver PCG;
preconditioner
tolerance 1e-07;
relTol 0;
nVcycles 2;
nPreSweeps 2;
tolerance 1e-07;
relTol 0;
maxIter 20;
"(U|k|C)"
smoother GaussSeidel;
tolerance 1e-06;
relTol 0.1;
nSweeps 1;
"(U|k|C)Final"
tolerance 1e-08;
relTol 0;
PIMPLE
momentumPredictor no;
nCorrectors 2;
nOuterCorrectors 1;
nNonOrthogonalCorrectors 0;
pRefCell 0;
pRefValue 0;
Hello people!
interfoam, scalar transport
Temperature calculation from total enthalpy in OpenFOAM (XiFOAM) sharifi OpenFOAM Running, Solving & CFD 1 October 8, 2020 09:16
Division by zero exception - loop over scalarField Pat84 OpenFOAM Programming & Development 6 February 18, 2017 05:57
problems concerning mass conservativity in bubbleFoam with custom scalar transport cutter OpenFOAM Programming & Development 3 February 10, 2015 04:25
dieselFoam problem!! trying to introduce a new heat transfer model vivek070176 OpenFOAM Programming & Development 10 December 23, 2014 23:48
Variable diffusion coefficient for scalar transport in interFoam amwitt OpenFOAM Programming & Development 5 September 10, 2013 19:12
