March 5, 2021, 23:55 |
Enforcing symmetric fields about a plane
simFoamer
Can setExprFields be used to enforce symmetric field about a plane? What is required is mentioned in the dict File below.
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2006 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object setExprFieldsDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // expressions ( U { field U; dimensions [0 1 -1 0 0 0 0]; // constants // { // } variables ( // ); condition #{ (pos().y() < 0) #}; expression #{ vector ( //To Do: mirror of velocity fields at pos().y()>0 to enforce symmetry through whole domain. Mesh is a 2D rectangular domain which has reflectional symmetry about y=0. (x-horizontal axis, y-vertical) // simulation of half domain and implementation of reflect filter in paraview works however, what is required is a code for enforcing symmetry at every time step by reflecting field values //of top half of domain to bottom half. setExprFields here is to figure this problem out (if that works) and take it as a reference which can be added to the code itself later. ) #}; } ); // ************************************************************************* // |
[Commercial meshers] faceSet of a cutting plane for a internal patch definition | RubenGutiii | OpenFOAM Meshing & Mesh Conversion | 1 | April 17, 2019 05:10 |
Channel flow with symmetry Plane not symmetric | Hillie | OpenFOAM Running, Solving & CFD | 0 | May 19, 2017 22:32 |
[DesignModeler] Body is not symmetric about xz plane, how to make that? | sifet | ANSYS Meshing & Geometry | 5 | August 31, 2015 04:05 |
Computation of Turbulence Intensity Profile from PIV vector fields | emspinosa | Visualization & Post-Processing | 0 | October 24, 2014 07:00 |
multiphaseEulerFoam: efficient way of implementing fields for all phases | maybee | OpenFOAM Programming & Development | 0 | January 23, 2014 04:16 |
