March 15, 2021, 11:26 |
pimpleFoam and porousBafflePressure
Pierre-Olivier Dallaire
I've been faced with a problem in the last few days with OpenFOAM 8 that I cannot resolve unfortunately. I'm using a porousBafflePressure BC on couple patches with a model that I'm solving with pimpleFOAM. For some reasons, this boundary condition is somewhat not applied. Some info: 1) For the mesh, the patches are defined as "cyclic" in boundary 2) the BCs are defined as "cyclic" for all fields except for the pressure 3) In the pressure file, I'm using this to define the porousBafflePressure: Code:
"porousBaffle" { type porousBafflePressure; patchType cyclic; jump uniform 0; value uniform 0; D 0; I 1.65; length 1; } 5) I ran in debug mode and I don't get the information that this BC should return Code:
<< " Average pressure drop :" << avePressureJump << " Average velocity :" << aveVelocity Any suggestion? Regards, PO |
April 12, 2021, 07:35 |
porousbafflepressure BC
Arnau
Rep Power: 5 |
I am having a similar problem when using porousBafflePressure BC. I am working with oenfoam v7 and I only found a tutorial using this boundary condition (damBreakPorousBaffle). My problem is that i am having the same solution with damBreakPorousBaffle and damBreak (without the porous baffle) like the porous membrane is not created or it is not affecting the fluid.
Do you have a set case using porousbafflepressure BC already working? |
March 6, 2023, 09:50 |
Mateusz Piecuch
Rep Power: 4 |
Hello
Have you found the answer? Or maybe someone have a tutorial for porous baffle? Best regards Mateusz |
pimpleFoam runs slower than rhoPimpleFoam | Kosuke Seto | OpenFOAM Running, Solving & CFD | 3 | May 27, 2023 14:12 |
pisoFoam and pimpleFoam are unstable in foam-extend 4.0/4.1 (misunderstanding ?) | Kombinator | OpenFOAM Running, Solving & CFD | 4 | January 14, 2021 04:10 |
naca12 laminar pimpleFoam | uni | OpenFOAM Running, Solving & CFD | 2 | March 17, 2018 07:17 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
Differences simpleFoam vs. pimpleFoam / RASModel.H vs turbulenceModel.H | uli | OpenFOAM Programming & Development | 7 | January 26, 2013 15:01 |
