Floating point exception (core dumped) Error with k-omega SST
Old   April 4, 2021, 11:32
Default Floating point exception (core dumped) Error with k-omega SST
Tom Waits
TomWaits is on a distinguished road
Hi FOAMers,
I am new to OpenFOAM and I am having an issue with running a case with kOmegaSST on v2006 - I don't have any issues with k-epsilon. I get the following cryptic error:
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kOmegaSST
Selecting patchDistMethod meshWave
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in /lib64/libpthread.so.0
#3  Foam::patchWave::getValues(Foam::MeshWave<Foam::wallPoint, int> const&) at ??:?
#4  Foam::patchWave::correct() at ??:?
#5  Foam::patchWave::patchWave(Foam::polyMesh const&, Foam::HashSet<int, Foam::Hash<int> > const&, bool) at ??:?
#6  Foam::patchDistMethods::meshWave::correct(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) at ??:?
#7  Foam::wallDist::wallDist(Foam::fvMesh const&, Foam::HashSet<int, Foam::Hash<int> > const&, Foam::word const&) at ??:?
#8  Foam::wallDist::wallDist(Foam::fvMesh const&, Foam::word const&) at ??:?
#9  Foam::wallDist const& Foam::MeshObject<Foam::fvMesh, Foam::UpdateableMeshObject, Foam::wallDist>::New<>(Foam::fvMesh const&) at ??:?
#10  Foam::kOmegaSSTBase<Foam::eddyViscosity<Foam::RASModel<Foam::IncompressibleTurbulenceModel<Foam::transportModel> > > >::kOmegaSSTBase(Foam::word const&, Foam::geometricOneField const&, Foam::geometricOneField const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel const&, Foam::word const&) at ??:?
#11  Foam::RASModels::kOmegaSST<Foam::IncompressibleTurbulenceModel<Foam::transportModel> >::kOmegaSST(Foam::geometricOneField const&, Foam::geometricOneField const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel const&, Foam::word const&, Foam::word const&) at ??:?
#12  Foam::RASModel<Foam::IncompressibleTurbulenceModel<Foam::transportModel> >::adddictionaryConstructorToTable<Foam::RASModels::kOmegaSST<Foam::IncompressibleTurbulenceModel<Foam::transportModel> > >::New(Foam::geometricOneField const&, Foam::geometricOneField const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel const&, Foam::word const&) at ??:?
#13  Foam::RASModel<Foam::IncompressibleTurbulenceModel<Foam::transportModel> >::New(Foam::geometricOneField const&, Foam::geometricOneField const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel const&, Foam::word const&) at ??:?
#14  Foam::TurbulenceModel<Foam::geometricOneField, Foam::geometricOneField, Foam::incompressibleTurbulenceModel, Foam::transportModel>::adddictionaryConstructorToTable<Foam::RASModel<Foam::IncompressibleTurbulenceModel<Foam::transportModel> > >::NewTurbulenceModel(Foam::geometricOneField const&, Foam::geometricOneField const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel const&, Foam::word const&) at ??:?
#15  ? at ??:?
#16  ? at ??:?
#17  __libc_start_main in /lib64/libc.so.6
#18  ? at ??:?
Here is my turbulenceProperties file:
|  \\    /   O peration     | Version:  v2006                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      turbulenceProperties;
simulationType RAS;
RAS
    RASModel            kOmegaSST;
    turbulence          on;
    printCoeffs         on;
my 0/k:
|  \\    /   O peration     | Version:  v1812                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      k;
kInlet          0.015; // approx k = 1.5*(I*U)^2
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform $kInlet;
boundaryField
    inlet
        type            turbulentIntensityKineticEnergyInlet;
        intensity       0.1;
        value           uniform $kInlet;
    outlet
        type            inletOutlet;
        inletValue      uniform $kInlet;
    slip1
        type            slip;
    slip2
        type            slip;
    symmetry1
        type            symmetryPlane;
    symmetry2
        type            symmetryPlane;
my 0/nut
FoamFile
    version     2.0;
    format      ascii;
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            calculated;
        value           uniform 0;
    outlet
        type            calculated;
        value           uniform 0;
    slip1
        type            slip;
    slip2
        type            slip;
    symmetry1
        type            symmetryPlane;
    symmetry2
        type            symmetryPlane;
and my 0/omega:
FoamFile
    version     2.0;
    format      ascii;
    object      omega;
omegaInlet      2.23607; // omega = Cu^-0.25*sqrt(k)/L , where Cu \approx 0.09
dimensions      [0 0 -1 0 0 0 0];
internalField   uniform $omegaInlet;
boundaryField
    inlet
        type            turbulentMixingLengthFrequencyInlet;
        mixingLength    0.1;
        value           uniform $omegaInlet;
    outlet
        type            inletOutlet;
        inletValue      uniform $omegaInlet;
    slip1
        type            slip;
    slip2
        type            slip;
    symmetry1
        type            symmetryPlane;
    symmetry2
        type            symmetryPlane;
Could anybody please give me some direction as to what the source of the error may be? I would be grateful for any help.
Many thanks in advance,
Tom Waits
TomWaits is offline   Reply With Quote
Old   April 7, 2021, 10:52
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hi Tom,
Not sure if this would be the reason, but it might be that if no value is being set explicitly a value of 0 is used. For omega this can result in a division by 0, which would blow up. As such it is maybe best to specify also a uniform value for the slip and symmetry boundaries:
    slip2
        type            slip;
    symmetry1
        type            symmetryPlane;
and similar for k and the other boundaries. It should not be necessary for nut, but no problems if you specify it there either.
If this does not help it is probably somewhere else, but I have no suggestion where to look.
Cheers,
Tom
tomf is offline   Reply With Quote
Error: Floating Point Exception. How do I fix this? Ryan T FLUENT 16 July 30, 2020 18:52
Floating point exception (core dumped) ramakant OpenFOAM Running, Solving & CFD 4 March 7, 2019 20:58
Floating point exception (core dumped), running a new solver Mahyar Javidi OpenFOAM Running, Solving & CFD 6 April 7, 2018 12:43
sonicFoam - Floating point eception (core dumped) MSans OpenFOAM Running, Solving & CFD 12 August 4, 2015 05:10
[waves2Foam] setWaveParameters application, it results in a floating point exception and the core psahoo87 OpenFOAM Community Contributions 1 February 4, 2015 12:42
