Error:printstack(Foam:0stream&) -OpenFoam 2.1.1.1 |
Rep Power: 5 ![]() |
I have the following error message as attached in OpenFoam, as I solve the case with ddtFoam. Do you have an idea how to solve the problem? Best regards Last edited by ulugbey; April 7, 2021 at 07:28. |
Robin Kamenicky
Rep Power: 11 ![]() |
Hi Ulugbey,
I am not familiar with the solver, but it seems that you are attempting to calculate xroot of negative value therefore you get sigFpe at pow function. It can be caused by many things. Most probably initial conditions, boundary conditions or some physical properties. It would be helpful if you post one iteration of properly running case using the solver to see what the expected output is. In other words at which variable it crashes. Other option is to run debug version to see exact line of error. Nevertheless, if you do not have much experience with OpenFOAM focus on the case configuration. Robin |
openfoam 2.1.1 |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 13:36 |
OpenFOAM Foundation Releases OpenFOAM v2.3.0 | opencfd | OpenFOAM Announcements from OpenFOAM Foundation | 3 | December 23, 2014 03:43 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
