The Model selection about MultiPhaseEulerFoam
Old   March 25, 2022, 03:28
Default The Model selection about MultiPhaseEulerFoam
ZY GONG
Gzy52597 is on a distinguished road
Hi Foamers,
I'm a newbie in OpenFOAM.My professor needed me to use MultiPhaseEulerFoam to solve some problems. But before I do that, I need to figure out the flow of this solver.
I read some code, like PhaseSystem.H createFields.H.But I still can't understand which code chooses the various models for my solution. For example, momentum transport model, heat transport model or other. How do they implement functionality? Pairing by using keywords?
Thank you very much.
GZY
Gzy52597 is offline   Reply With Quote
Old   March 25, 2022, 03:52
Kumaresh
Kummi is on a distinguished road
Send a message via Yahoo to Kummi
Firstly, what's the real time application behind your problem ?
To figure out the flow of solver, use debugger called nemiver in OpenFoam.
Thank you
Kummi is offline   Reply With Quote
Old   March 25, 2022, 08:03
ZY GONG
Thank you
Thanks for your reply, I'll try it.Good luck for you.
multiphaseeulerfoam
Selection of model and calculation of Reynolds no sanket2309 CFX 0 December 9, 2019 22:33
[ANSYS Meshing] Script Connection Friction arpeedesign ANSYS Meshing & Geometry 4 April 11, 2019 08:17
Define different turbulence model for each phase (multiphaseEulerFoam) remidemol OpenFOAM Running, Solving & CFD 2 February 27, 2018 17:57
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Thermal radiation model selection and application Jason Phoenics 14 November 18, 2005 05:21
