different between serial and parallel running in reading pointzone
Old   May 7, 2021, 03:15
Default different between serial and parallel running in reading pointzone
Hojatollah Gholami
Hgholami is on a distinguished road
Dear foamer
I have problem with parallel simulation of new cases.
I have a pointZone as movingPointsZone that read by this code in a solver
const pointZone& pz = fvMesh_.pointZones()[movingPointsZone_];
Info <<pz<<endl;
when I run serial, the output is same as pointZone in polyMesh/pointZone.
when I decompose mesh and run parallel, the output is very deference.
for example
in serial
movingPoints
82464
131072
131073
131074
131075
131076
in parallel
movingPoints
6272
23002
23003
23004
23005
23006
23007
23008
if I change decompose method
movingPoints
6272
15918
15919
15920
in parallel running, the ids is all deference from pointZone, why?
Thanks
Hgholami is offline   Reply With Quote
foam-extend 4.0
multiphaseEulerFoam running in serial but crashing in parallel BlnPhoenix OpenFOAM Running, Solving & CFD 1 May 4, 2017 03:40
Loop through processors and collect cellLabels of celLZone hxaxtma OpenFOAM 13 March 22, 2017 14:08
Case running in serial, but Parallel run gives error atmcfd OpenFOAM Running, Solving & CFD 18 March 26, 2016 12:40
Case running in parallel gives error whereby running in serial works Harak OpenFOAM Running, Solving & CFD 8 October 17, 2015 11:12
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
