June 5, 2021, 23:47 |
Solution blows in multiPhase solver
Rep Power: 10 |
Greetings,
EDIT: Issue solved. GCC 11 was causing the issue. Last edited by venkcy; June 12, 2021 at 23:49. Reason: Updated the OF build log |
viscosity udf don't use correct temperature and strain rate | rezvani | Fluent UDF and Scheme Programming | 8 | May 27, 2021 05:40 |
An unknown error occurred during solution. Check the Solver Output on the Solution I | hitzhwan | Main CFD Forum | 0 | May 20, 2020 11:56 |
Epyc 7551 vs 6850K; Ansys Mechanical Bench | Duke711 | Hardware | 24 | March 26, 2020 10:16 |
Shape optimization doesn't converge - Adjoint log file | JPBLourenco | SU2 Shape Design | 0 | December 11, 2017 08:41 |
Incompressible multiphase solver with laplaceelectrostatic solution | coastal593 | OpenFOAM Running, Solving & CFD | 2 | January 9, 2008 12:57 |
