pyFoam on cluster error: : Unknown or missing MPI-Implementation: EASYBUILDMPI |
June 15, 2021, 05:58 |
Javier Vinuales
Rep Power: 10 |
Hi everyone,
I am trying to run a script using pyfoam. The script runs in my machine without any problems. When I try to run in a cluster I get the following error: FatalError in PyFoam: 'PyFoam FATAL ERROR on line 63 of file /nvme/h/es21jv1/.local/lib/python3.8/site-packages/PyFoam/Execution/ParallelExecution.py: Unknown or missing MPI-Implementation: EASYBUILDMPI' The python code specific for this error is the following: Code:
Runner(args=["--auto","potentialFoam"]) Thanks! Javier |
June 15, 2021, 09:09 |
Javier Vinuales
Rep Power: 10 |
The following option does not work neither:
Runner(args=["--procnr=40","potentialFoam"]) FatalError in PyFoam: 'PyFoam FATAL ERROR on line 63 of file /nvme/h/es21jv1/.local/lib/python3.8/site-packages/PyFoam/Execution/ParallelExecution.py: Unknown or missing MPI-Implementation: EASYBUILDMPI' |
June 15, 2021, 09:51 |
Javier Vinuales
Rep Power: 10 |
Any help would be appreciated!
Thanks. |
June 16, 2021, 10:16 |
Javier Vinuales
Rep Power: 10 |
I installed without apparent problem using:
pip install PyFoam Other PyFoam commands run without problem, such as: Code:
from PyFoam.Applications.Runner import Runner Runner (args=["decomposePar"]) |
June 21, 2021, 08:31 |
Javier Vinuales
Rep Power: 10 |
anyone any help?
pyfoam |
mpirun, best parameters | pablodecastillo | Hardware | 18 | November 10, 2016 12:36 |
MPI Implementation | AshwaniAssam | Main CFD Forum | 3 | July 11, 2015 10:45 |
Problems with MPI implementation | francesco_capuano | OpenFOAM Installation | 7 | January 16, 2013 01:53 |
MPI implementation of OpenFOAM | Jamshidi | OpenFOAM | 7 | June 25, 2011 09:19 |
Implementation of MPI | Ertan Karaismail | Main CFD Forum | 5 | May 17, 2009 11:31 |
