Floating box falling through the water
Old   June 18, 2021, 08:49
Default Floating box falling through the water
Carlos Eduardo Simões de Almeida
cesa is on a distinguished road
Hello, everyone!
I'm using OpenFOAM-v1912 and the case floatingObject as a base case, which uses the overInterDyMFoam solver. I have just changed the geometry of the floating object and the background (my simulation is 2D) and added a waveProperties dictionary in background/system. The wave and the mesh seem fine.
Nevertheless, when I run the simulation, the floatingObject falls through the water in the first 0.15 second (using a timeStep of 0.05s), even though the simulation runs smoothly until the endTime (20s), with no severe mesh deformation in the background mesh (which is the only mesh left).
I've tried different ways of meshing, such as:
(1) Generate the floatingObject using blockMesh -> use topoSet and subsetMesh to generate the overset mesh of the floating body.
Generate the background mesh using blockMesh -> merge the background and floatingObject meshes using mergeMeshes -> use topoSet to select cellSets for the different zones
(2) Generate the floatingObject using blockMesh and use a .stl file and snappyHexMesh to create the floatingObject overset mesh.
The object falls through the water in both methods.
Do you guys know what may be causing this? I'm attaching my log file (reduced because the original one is too big) and we can see that the z-force becomes large, but why?
Thank you in advance!
Best regards,
Carlos
cesa is offline   Reply With Quote
Old   June 19, 2021, 18:08
Anyone?
Damping Constant for a Floating Box RJKhan Structural Mechanics 0 December 27, 2016 18:09
Monitor surface area of an oil slick floating on water visitor FLUENT 0 November 3, 2014 09:53
2D Box dropping into water kailingkk Fluent Multiphase 1 April 9, 2014 19:06
Floating objects in water flow: which tools and how much effort ? TomGratte1 Main CFD Forum 0 December 29, 2013 10:43
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
