June 23, 2021, 20:31 |
OpenFOAM_FOAM FATAL ERROR
A
Rep Power: 7 |
Hi guy,
I am running radiation heat transfer in buildings with solver "buoyantSimpleFoam". But I meet this problem."FOAM FATAL ERROR: Maximum number of iterations exceeded: 100" (I have attached the picture) Could I ask you a question? how to handle this issue? Thank you in advance. I hope you are doing well |
June 24, 2021, 00:36 |
Uwe Pilz
You should check your temperature connected boundary conditions. Other reasons my be awkward initialization for T. Do you have any heat sources? Look at them, if they go to very high values.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
June 24, 2021, 03:27 |
A
Rep Power: 7 |
Hi Sir,
Thank you so much for your support |
[OpenFOAM] ParaView command in Foam-extend-4.1 | mitu_94 | ParaView | 0 | March 4, 2021 13:46 |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 20:30 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
