Force Oscillations in sloshing simulation with dynamicMeshDict (6DoF)
Old   February 9, 2024, 08:47
Question Force Oscillations in sloshing simulation with dynamicMeshDict (6DoF)
thr
thr
thr is on a distinguished road
im try to simulate sloshing in a closed tank.
I use OF11 and based on the tutorial sloshingTank6DoF i built up my own simulation. In the end i want the forces acting on the tank due to the liquid sloshing. When i read the data from the postProcessing folder i get really confusing Oscillations. I have no clue why this is happening. I have tried several different options in fvSchemes and fvSolution.
controlDict:
application foamRun;
solver incompressibleVoF;
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 1;
deltaT 0.0001;
writeControl adjustableRunTime;
writeInterval 0.1;
purgeWrite 0;
writeFormat binary;
writePrecision 9;
writeCompression off;
timeFormat general;
timePrecision 9;
runTimeModifiable yes;
adjustTimeStep yes;
maxCo 0.4;
maxAlphaCo 0.4;
maxDeltaT 0.01;
functions
forces
type forces;
libs ("libforces.so");
patches ("sloshingCylinder");
log on;
writeInterval 0.001;
rhoInf 1000;
rho rhoInf;
CofR (0.4 -0.4 0.1); // Point for calculation of moments
fvSolution
solvers
alpha.water
nAlphaCorr 1;
nAlphaSubCycles 3;
"pcorr.*"
solver PCG;
preconditioner
preconditioner GAMG;
tolerance 1e-05;
relTol 0;
smoother DICGaussSeidel;
cacheAgglomeration no;
tolerance 1e-05;
relTol 0;
maxIter 100;
p_rgh
solver GAMG;
tolerance 1e-08;
relTol 0.01;
smoother DIC;
p_rghFinal
solver PCG;
preconditioner
tolerance 2e-09;
relTol 0;
nVcycles 2;
nPreSweeps 2;
tolerance 2e-09;
relTol 0;
maxIter 20;
"(U|k|epsilon|omega).*"
solver smoothSolver;
smoother GaussSeidel;
tolerance 1e-06;
relTol 0;
nSweeps 1;
PIMPLE
momentumPredictor no;
nCorrectors 5;
nNonOrthogonalCorrectors 1;
correctPhi no;
pRefPoint (0.4 -0.4 0.1);
pRefValue 1e5;
relaxationFactors
equations
".*" 1;
dynamicMeshDict
mover
type motionSolver;
libs ("libfvMeshMovers.so" "libfvMotionSolvers.so");
motionSolver solidBody;
select all;
solidBodyMotionFunction sixDoFMotion;
CofG (0.4 -0.4 0.1);
translationRotation table;
//interpolationScheme spline;
file "$FOAM_CASE/constant/6DoF.dat";
6DoF.dat is a table with a frequency of 800hz. simple acceleration in x direction with 9.81m/s^2.
I have attached a plot of the force. Its the same for Fx,Fy,Fz. Every 10nth data point drops. The sloshing in Paraview look good. I think this could be a problem with the dynamictMeshDict, the forcesFunction or the adjustableTimeStep.
Best,
T
thr is offline   Reply With Quote
Drag Force Ratio for Flat Plate Rob Wilk Main CFD Forum 40 May 10, 2020 04:47
Z-dimension for 2D 6DoF simulation Fieschi OpenFOAM Pre-Processing 1 March 29, 2020 23:01
Incorrect lift force in simpleFoam airfoil simulation olov OpenFOAM Running, Solving & CFD 2 May 18, 2019 06:51
Massless 6DOF Simulation Mojtaba.a OpenFOAM Running, Solving & CFD 1 February 14, 2016 07:54
VOF Sloshing - beating pattern in force output? Brian FLUENT 0 May 18, 2006 10:59
