Temperature anomoly at pressure reference cell
Like Tree5Likes
Old   February 14, 2011, 15:17
Default Temperature anomoly at pressure reference cell
Will Logie
will.logie is on a distinguished road
Hello Foamers,
I've been witnessing temperature divergence at the pressure reference cell in a buoyantBoussinesqPimpleFoam problem I've defined axi-symmetrically; a cylindrical hot water tank with a helix-coiled heat exchanger became a 2° wedge of 1 cell thickness. The picture attached hopefully gives an idea of this. In it you can also see where I placed the pressure reference and how the temperature (shown here at 25 seconds) at this point is rising (inexplicably for my liking) and causing all sorts of mischief.
Here my fvSolution:
|  \\    /   O peration     | Version:  1.7.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p_rgh
        solver                  PCG;
        preconditioner          DIC;
        tolerance               1e-8;
        relTol                  0.01;
    p_rghFinal
        $p_rgh;
        relTol                  0;
    "(U|T|k|epsilon|omega|R)"
        solver                  PBiCG;
        preconditioner          DILU;
        tolerance               1e-6;
        relTol                  0.1;
    "(U|T|k|epsilon|omega|R)Final"
        $U;
        relTol                  0;
PIMPLE
    momentumPredictor             yes;
    nOuterCorrectors             1;
    nCorrectors                 2;
    nNonOrthogonalCorrectors     0;
    //pRefPoint                    ( 0.25 0.13 0 );
    pRefCell                    684;
    pRefValue                   0;
relaxationFactors
    "(U|T|k|epsilon|omega|R)"                     1;
    "(U|T|k|epsilon|omega|R)Final"                 1;
and fvSchemes:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss upwind;
    div(phi,T)      Gauss upwind;
    div(phi,k)      Gauss upwind;
    div(phi,epsilon) Gauss upwind;
    div(phi,omega) Gauss upwind;
    div(phi,R)      Gauss upwind;
    div(R)          Gauss linear;
    div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
    default         none;
    laplacian(nuEff,U) Gauss linear uncorrected;
    laplacian((1|A(U)),p_rgh) Gauss linear uncorrected;
    laplacian(kappaEff,T) Gauss linear uncorrected;
    laplacian(DkEff,k) Gauss linear uncorrected;
    laplacian(DepsilonEff,epsilon) Gauss linear uncorrected;
    laplacian(DomegaEff,omega) Gauss linear uncorrected;
    laplacian(DREff,R) Gauss linear uncorrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         uncorrected;
fluxRequired
    default         no;
    p_rgh           ;
Any ideas?
Thanks,
Will.
raj kumar saini likes this.
will.logie is offline   Reply With Quote
Old   February 16, 2011, 06:31
Default Anomaly in the sense that...
Will Logie
... the temperature at pRefCell oscillates in time from being the lowest (~265K) to the highest (~310K).
In previous cases where I had not yet included the axi-symmetry of the problem (simple 2D extruded mesh) I was not witnessing this in any way. I am thus inclined to think that my error lies therein but am ill equipped to diagnose further. I'd really appreciate some thoughts from you experts out there!
Old   February 16, 2011, 08:33
Default checkMesh failed?
Will Logie
The only thing I can see that seems remotely suspicious is a point in the front wedge slipping outside a threshold (1e-8 meter?). I created the mesh in what I thought was a rather cleanly parameterised gmsh file:
|  \\    /   O peration     | Version:  1.7.x                                 |
Build  : 1.7.x-da2e560009e6
Exec   : checkMesh
Date   : Feb 16 2011
Time   : 14:25:58
Host   : pc-spf-163
PID    : 14620
Case   : /home/will/OpenFOAM/will-1.7.x/run/ihx/buoyantBoussinesqPimpleFoam/ihx35mmCourseWedge
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    internal points:  0
    faces:            23470
    internal faces:   11521
    cells:            5846
    boundary patches: 5
    point zones:      0
    face zones:       0
    cell zones:       1
Overall number of cells of each type:
    hexahedra:     5761
    prisms:        85
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
    Patch               Faces    Points   Surface topology
    tesWall             209      418      ok (non-closed singly connected)
    front               5846     6017     ok (non-closed singly connected)
    pipeWall            48       96       ok (non-closed singly connected)
    back                5846     6017     ok (non-closed singly connected)
    defaultFaces        0        0        ok (empty)
Checking geometry...
    Overall domain bounding box (0 0 -0.00567203) (0.324951 0.3 0.00567203)
    Mesh (non-empty, non-wedge) directions (1 1 0)
    Mesh (non-empty) directions (1 1 1)
    Wedge front with angle 1.00004 degrees
 ***Wedge patch front not planar. Point (0.260332 0.0457038 0.00454412) is not in patch plane by 3.73728e-08 meter.
    Boundary openness (-2.60064e-19 6.7127e-20 6.3524e-19) OK.
    Max cell openness = 3.04681e-16 OK.
    Max aspect ratio = 9.45051 OK.
    Minumum face area = 1.83948e-07. Maximum face area = 0.000137058.  Face area magnitudes OK.
    Min volume = 1.54238e-09. Max volume = 3.80042e-07.  Total volume = 0.000550207.  Cell volumes OK.
    Mesh non-orthogonality Max: 41.1657 average: 8.53724
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 0.952198 OK.
Failed 1 mesh checks.
End
Old   February 18, 2011, 10:51
Default ... a bigger example
Will Logie
... after 200 seconds.
Old   April 5, 2011, 19:52
Eugene de Villiers
eugene is on a distinguished road
Well your checkMesh says the front plane of the wedge is non-planar. If you still have the problem try replacing the wedge boundaries with symmetryPlane - if the problem goes away, then the issue is your mesh not being a perfect enough wedge.
eugene is offline   Reply With Quote
Old   April 6, 2011, 04:42
Default ascii -> binary
Will Logie
If one looks inside the average controlDict file there are these two settings which I never really paid attention to before; writeFormat and writePrecision.
Changing writeFormat to binary worked a charm... (thank you Mattijs!)
Overall domain bounding box (0 0 -0.00567203) (0.324951 0.5 0.00567203)
Wedge front with angle 1 degrees
Wedge back with angle 1 degrees
All edges aligned with or perpendicular to non-empty directions.
Boundary openness (1.06916e-19 5.56146e-20 -8.77993e-19) OK.
Max cell openness = 3.05762e-16 OK.
Max aspect ratio = 4.96254 OK.
Minumum face area = 1.22973e-07. Maximum face area = 3.30134e-05. Face area magnitudes OK.
Min volume = 6.95689e-10. Max volume = 7.61277e-08. Total volume = 0.000910615. Cell volumes OK.
Mesh non-orthogonality Max: 42.3953 average: 9.13043
Face pyramids OK.
Max skewness = 0.529742 OK.
Mesh OK.
Old   April 13, 2011, 13:06
Carlos Xisto
xisto is on a distinguished road
Send a message via MSN to xisto
After run makeAxialMesh and collapseEdges.
I found a similar problem. however ascii to binary doesn't work for me.
My grid looks fine and the checkMesh before the makeAxialMesh and collapseEdges reports no errors.
Any suggestions?
Thanks
Carlos
Create time
Time = 0
Mesh stats
    internal points:  0
    faces:            5558
    internal faces:   2659
    cells:            1386
    boundary patches: 7
    point zones:      0
    face zones:       0
    cell zones:       0
    hexahedra:     1287
    prisms:        99
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
    Point usage OK.
    Face vertices OK.
    front-back          0        0        ok (empty)
    inlet               14       29       ok (non-closed singly connected)
    outlet              14       29       ok (non-closed singly connected)
    simetry             0        0        ok (empty)
    wall                99       200      ok (non-closed singly connected)
    front-back_pos      1386     1500     ok (non-closed singly connected)
    front-back_neg      1386     1500     ok (non-closed singly connected)
    Overall domain bounding box (0 1 -0.360028) (10 3.035 1.36003)
    Wedge front-back_pos with angle 22.91 degrees
 ***Wedge patch front-back_pos not planar. Point (0.10101 1 0.5) is not in patch plane by 1.28966e-06 meter.
    Boundary openness (5.88638e-18 -1.0902e-15 -5.47392e-16) OK.
    Max cell openness = 2.36954e-16 OK.
    Max aspect ratio = 2.83371 OK.
    Minumum face area = 0.00215678. Maximum face area = 0.241098.  Face area magnitudes OK.
    Min volume = 0.000218165. Max volume = 0.0227451.  Total volume = 8.04848.  Cell volumes OK.
    Mesh non-orthogonality Max: 21.5012 average: 8.88707
    Face pyramids OK.
    Max skewness = 1.05346 OK.
End
xisto is offline   Reply With Quote
Old   April 14, 2011, 04:55
Will Logie
Originally Posted by xisto View Post
    Face pyramids OK.
End
Which axis are you straddling (z)? The wedge has to straddle the axis which you are collapsing equally and it looks to me like you are offset to one side -> Overall domain bounding box (0 1 -0.360028) (10 3.035 1.36003)
23° is a pretty big wedge too. Maybe try <5°...?
Which settings did you use for collapseEdges?
Old   April 14, 2011, 05:03
Carlos Xisto
Hello Will and thank you for your reply.
I have already tried with 5 degrees and I get the same result. For the collapseEdges I used 1e-8 and 180 degrees
Time = 0
Mesh stats
    internal points:  0
    faces:            5558
    cells:            1386
    boundary patches: 7
    point zones:      0
    face zones:       0
    cell zones:       0
    hexahedra:     1287
    prisms:        99
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
    Point usage OK.
    Face vertices OK.
    Overall domain bounding box (0 1 0.411235) (10 3.035 0.588765)
    Wedge front-back_pos with angle 2.49762 degrees
 ***Wedge patch front-back_pos not planar. Point (0.10101 1 0.5) is not in patch plane by 5.03641e-07 meter.
    Boundary openness (6.12585e-19 -3.61958e-17 -8.53818e-16) OK.
    Max cell openness = 2.13747e-16 OK.
    Minumum face area = 0.000222607. Maximum face area = 0.0248842.  Face area magnitudes OK.
    Min volume = 2.25174e-05. Max volume = 0.00234757.  Total volume = 0.830702.  Cell volumes OK.
    Face pyramids OK.
    Max skewness = 0.516369 OK.
Old   April 14, 2011, 05:30
Default Hmmm...
Will Logie
Hey Carlos,
I've just had a quick look at my makeAxialMesh example and found that this problem you mention persists for me too when I use makeAxialMesh, regardless of binary and writePrecision.
The example where ascii -> binary worked for me (post from April 6th) does not use makeAxialMesh. There I create the wedge in gmsh (translate mesh -1° about symmetryPlane and extrude/revolve 2° about symmetryPlane) and convert that to foam. So I'm not sure I can help you much further with makeAxialMesh - are you using gmsh?
I'm also not sure if you need to straddle the xy-plane equally or not. Maybe someone else can comment on the interpretation from the user manual:
For 2 dimensional axi-symmetric cases, e.g. a cylinder, the geometry is specified as a wedge of small angle (e.g. ) and 1 cell thick running along the plane of symmetry, straddling one of the coordinate planes
Old   April 14, 2011, 05:34
Carlos Xisto
I'm using Pointwise for the grid.
Thanks for your help anyway.
What is curious is that the test case that came with makeAxial reports the same error.
Old   April 2, 2012, 16:39
jdiorio is on a distinguished road
I'm seeing the same issue, except the mesh isn't axisymmetric. The mesh is a cube of hexahedral cells, looking at a buoyancy flows (solving for piezometric pressure "pd" instead of "p = pd + rhogh"). "pd" is set to "zeroGradient" on all boundaries, and the reference value for pdEqn is supplied by calculating the total pressure:
if (pd.needReference())
p += dimensionedScalar
"p",
p.dimensions(),
pRefValue - getRefCellValue(p, pRefCell)
pd = p - rhokamb*gh;
Everything runs fine when you specify the temperature of the top/bottom boundaries (e.g. "fixedValue") - but if you change one of the boundaries (say to "zeroGradient"), the temperature in the cell that corresponds to "pRefCell" increases, like will.logie showed. I've tried moving the reference cell around, but wherever you move it, that's where you see the temperature anomaly. It's strange because one of the temperature boundaries is still fixed, so a check to something like:
if (T.needReference())
Info << "Applying reference temperature " <<
getRefCellValue(T,pRefCell) << " at point " <<
mesh.C()[pRefCell] << endl;
doesn't spit out anything, so I can only assume that the TEqn doesn't need a reference cell. Of course, if I set all the temperature boundaries to "zeroGradient" this loop spits out info, and you can see the temperature in that cell getting changed...
How/where could "pRefCell" be entering into the TEqn? Any thoughts?
Thanks.
jdiorio is offline   Reply With Quote
Old   April 5, 2012, 16:36
To try to offer up some more information...
The error comes during the TEqn.solve() step. If you look at the temperature at the cell "pRefCell" you can see it changing wildly after the solution. Changed the top boundary type on T to "fixedGradient" (instead of trying "zeroGradient"), setting the gradient equal to the temperature gradient for the stratification (linear stratification). Bottom boundary still constant value. This appears to fix the problem running in serial, but in parallel the error occurs - the temperature in the cell that corresponds to "pRefCell" becomes unphysical. Attached is a snapshot of what the parallel solution looks like after about 50 iterations.
Any thoughts on how pRefCell could be interfering with the TEqn, even though one of the temperature equation boundaries is a "fixedValue"? This happens in both OF-2.1.0 and OF-1.6-ext (tried both). Tried different solvers for T as well (PCBiCG and GAMG), same deal. Also, when I use a "fixedGradient" at the top, why would it work in serial but not in parallel?
Old   April 10, 2012, 08:50
Bump. To try and provide some more info, wrote out the location of the pressure reference cell, and then applying:
TEqn.setReference(pRefCell,T.internalField()[pRefCell]);
to see if it's actually setting a temperature reference. Here it would basically set the reference temperature to whatever it was before the TEqn.solve(). Here is an example output - notice how T[pRefCell] is increasing and not equal to what it was before the solve....
Time = 0.01
Courant Number mean: 0.00783788 max: 0.346089
DILUPBiCG:  Solving for Ux, Initial residual = 0.00193302, Final residual = 4.01574e-10, No Iterations 3
DILUPBiCG:  Solving for Uy, Initial residual = 0.00193302, Final residual = 4.01574e-10, No Iterations 3
DILUPBiCG:  Solving for Uz, Initial residual = 0.00298749, Final residual = 7.85053e-10, No Iterations 3
DICPCG:  Solving for pd, Initial residual = 1, Final residual = 9.99605e-09, No Iterations 313
time step continuity errors : sum local = 2.48078e-09, global = -2.47807e-09, cumulative = -2.47807e-09
DICPCG:  Solving for pd, Initial residual = 0.00911823, Final residual = 9.80415e-09, No Iterations 283
time step continuity errors : sum local = 2.48337e-09, global = -2.47807e-09, cumulative = -4.95615e-09
pRefCell location = (-7.5 -8.9 -19.3)
Setting reference temperature at (-7.5 -8.9 -19.3) to 299.397
T[pRefCell] = 299.397
DILUPBiCG:  Solving for T, Initial residual = 8.09426e-06, Final residual = 8.37418e-09, No Iterations 1
T[pRefCell] = 299.768
ExecutionTime = 50.21 s  ClockTime = 51 s
Time = 0.02
Courant Number mean: 0.000653823 max: 0.393349
DILUPBiCG:  Solving for Ux, Initial residual = 0.952681, Final residual = 1.70106e-10, No Iterations 3
DILUPBiCG:  Solving for Uy, Initial residual = 0.952681, Final residual = 1.70104e-10, No Iterations 3
DILUPBiCG:  Solving for Uz, Initial residual = 0.92743, Final residual = 3.8282e-10, No Iterations 3
DICPCG:  Solving for pd, Initial residual = 0.955734, Final residual = 9.13164e-09, No Iterations 307
time step continuity errors : sum local = 1.65392e-09, global = -1.65143e-09, cumulative = -6.60758e-09
DICPCG:  Solving for pd, Initial residual = 0.0156603, Final residual = 9.83983e-09, No Iterations 288
time step continuity errors : sum local = 1.65325e-09, global = -1.65143e-09, cumulative = -8.25901e-09
Setting reference temperature at (-7.5 -8.9 -19.3) to 299.768
DILUPBiCG:  Solving for T, Initial residual = 7.12715e-06, Final residual = 2.1977e-09, No Iterations 1
T[pRefCell] = 299.995
ExecutionTime = 85.37 s  ClockTime = 86 s
I've actually tried this specifying some other cell and some other value, which does fix the temperature at that NEW cell, but the value at the old cell still diverges...
Old   August 29, 2012, 09:39
So I think I found a solution. The strange temperature behavior at pRefCell was not coming from the temperature equation, but from the pressure equation. During the pressure solution, the value of the density perturbation (rhok) at pRefCell would fluctuate. I'm not 100% certain yet, but it's related to the fact that the flux needs to be adjusted AFTER the inclusion of buoyancy. That is, in pEqn.H:
surfaceScalarField phiU
        (fvc::interpolate(U) & mesh.Sf())
//adjustPhi(phiU, U, pd);
phi = phiU + (rAUf * ((fvc::interpolate(rhok)) * (g & mesh.Sf())));
adjustPhi(phi, U, pd);
The old version of the code I was using did the adjustment prior to the inclusion of the buoyancy term (see comment in code above). Adjusting the flux after the inclusion of buoyancy makes more sense, since the flux that gets adjusted and the flux used in the pressure equation are now the same. Oddly enough it fixes the issue with the density - bit puzzling but this implementation makes more sense to me and fixes the issue I was having. Perhaps the inconsistency in the fluxes causes rhok to be set at pRefCell during the pressure solution?
Old   June 5, 2013, 18:55
Default pRefCell on Parallel Simuations
  #16
Yahoo is on a distinguished road
Hi
I have developed a solver which works fine on single processor, but diverges when I am running it on multiple processors. For the later, by changing the cell at which pressure is set (pRefCell), my results change. i.e. pRefCell is affecting the results on parallel simulations! Any hints?
Yahoo is offline   Reply With Quote
Old   August 30, 2013, 16:58
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Dear all,
For those who have the problem about wedge patch which was mentioned above, I want to inform that I solved the problem using Bernhard Gschaider's post in here:
http://www.cfd-online.com/Forums/ope...tml#post387133
  • You have got to change writePrecision value to 12 and rerun the mesh manipulation. after finishing change writePrecision value back to 6.
  • Run checkMesh and problem is gone.
I hope it helps a bit,
Mojtaba
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Old   September 1, 2013, 11:21
immortality's Avatar
Ehsan
immortality is on a distinguished road
Hi Mojtaba
how writePrecision can help?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   September 1, 2013, 14:29
Mojtaba.a's Avatar
Originally Posted by immortality View Post
Hi Mojtaba
Hi Ehsan,
Well more values of writePrecision will make OF to write values with more accuracy.
In wedge problems, having a symmetry geometry is one of the main concerns, therefore we are trying to obtain more accuracy in order to have a much better symmetry in our geometry.
Changing writePrecision will help this.
Old   March 19, 2014, 08:11
Nima Samkhaniani
nimasam is on a distinguished road
another suggestion which works for me was like that:
 fvScalarMatrix p_rghEqn
            fvm::laplacian(rAUf, p_rgh) == fvc::div(phiHbyA)
          p_rgh = p-rhok*gh;
          p_rghEqn.setReference(pRefCell, getRefCellValue(p_rgh, pRefCell));
        p_rghEqn.solve(mesh.solver(p_rgh.select(pimple.finalInnerIter())));
manuc likes this.
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Installing OpenFOAM-1.5-dev on a cluster ZKM OpenFOAM Installation 4 December 25, 2010 15:59
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
