July 29, 2021, 04:45 |
Gas injection in the middle of a domain
Rep Power: 4 |
I am quite new to openfoam and I would like to simulate the following situation. I have a pipe, closed at one end filled with air at ambient pressure and temperature. Inside the pipe I have the solid region which is a heat source and where we want to monitor the temperature. From this region, there is gas at high pressure and temperature which is ejected and mixing with the air already present in the pipe. (I attached a picture to be clearer) I have already simulated the pipe with the solid region using chtMultiRegionFoam and now I want to add the gas injection. However, I don't know how to add this gas inlet inside the domain and I am not even sure that chtMultiRegionFoam is the appropriate solver to do this. If anyone could share its idea and propositions, I would be very glad to hear them ! Thank you very much ! |
boundaries definition, chtmulitregionfoam, heat transfer, injection |
Injection injection-0: LOST 2 out of 20 injection locations | attaullah | FLUENT | 17 | March 2, 2023 10:31 |
Problem with gas mixing in closed domain | Nheni | CFX | 6 | February 19, 2021 22:26 |
Injection of gas into tube with small holes - Supersonic flow | mrsl | Main CFD Forum | 0 | December 5, 2018 06:49 |
Floating point exception: Zero divide | liladhar | CFX | 11 | December 16, 2013 04:07 |
