Checkerboarding problem_simpleFoam
Old   August 9, 2021, 10:39
Default Checkerboarding problem_simpleFoam
subhojitkadiacfd is on a distinguished road
Hello Everyone,
I am working on very simple steady state solution (2D) of a channel flow using simpleFoam and having single cell along the flow direction (x).
I have used periodic boundary condition for inlet and outlet, noSlip (for U) for the walls. I have tried different available fvSchemes.
However, getting checkerboarding issue with p, Uy and Uz.
Any suggestions to eliminate the issue will be highly appreciated. Thanks.
Subho
subhojitkadiacfd is offline   Reply With Quote
Old   August 9, 2021, 11:18
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
First: Periodic b.c. often lead to problems. You are in 2D. It may be much better stacking some of the geometries and avoid periodicity in b.c.
Second: Checkerboarding is an issue of Mesh, may be combined with schemes. Try using a finer mesh.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   August 9, 2021, 12:18
Many thanks for your reply Uwe. In my case, I have restrict to a 2D simulation. I have used fine mesh.
Subhojit
Old   August 9, 2021, 23:58
piu58's Avatar
Uwe Pilz
In most cases, the main question is not
How may I get my simulation running
but
How do I change my real world problem into a simulation.
Normally, there are no such restrictions. We have to select the simulation which gives the most reliable results. Often, this is the simplest one.
If you want to stay your simulation, I recommend using more stable schemes and relaxation.
Uwe Pilz
Old   August 13, 2021, 10:17
Hello Uwe,
Thanks for your reply. I am using the following schemes
ddtSchemes
    default         steadyState;
gradSchemes
    default 		Gauss linear; //cellLimited Gauss linear 1;
divSchemes
    default				none;
	div(phi,U)  		bounded Gauss limitedLinearV 1;//bounded Gauss linearUpwind grad(U);
    div(phi,k)      	bounded Gauss limitedLinear 1;
    div(phi,epsilon) 	bounded Gauss limitedLinear 1;
	div((nuEff*dev2(T(grad(U))))) Gauss linear;
    div((nu*dev2(T(grad(U))))) Gauss linear;//For LRR, SSG
	div(phi,R)      	bounded Gauss limitedLinear 1; //For LRR, SSG
    div(R)          	Gauss linear; //For LRR, SSG
laplacianSchemes
    //default         Gauss linear corrected;
	default 		Gauss linear orthogonal;
interpolationSchemes
    default 		linear;
	//interpolate(U) 	linear;
snGradSchemes
    //default         corrected;
	default 		orthogonal;
fluxRequired
	default	no;
	p;
wallDist
	method			meshWave;
Relaxation:
for p 0.3 and for rest 0.7. I have also tried with lower/higher relaxations.
But no noticeable improvements.
Subhojit
but
checkerboarding, simplefoam convergence, steady state
Causes of checkerboarding sturgeon OpenFOAM Running, Solving & CFD 15 September 4, 2019 02:35
Checkerboarding > SimpleFoam yambanshee OpenFOAM 2 February 6, 2019 05:12
Checkerboarding stuart23 Main CFD Forum 4 October 16, 2012 09:36
Checkerboarding problem in LES Matteo85 OpenFOAM Running, Solving & CFD 3 September 15, 2012 22:15
Checkerboarding problem in LES Matteo85 OpenFOAM Running, Solving & CFD 0 June 9, 2009 09:47
