viscoelastic fluid flow at the creeping regime using rheoFoam
Old   August 27, 2021, 22:45
Default viscoelastic fluid flow at the creeping regime using rheoFoam
A. Min
alimea is on a distinguished road
Hi all
I want to simulate the viscoelastic fluid flow in a curved duct at the creeping flow regime using rheoFoam solver. I solved this problem in the inertial regime and got good convergence, physical results, and short run-time in both low and high Weissenberg numbers. But the problem is very sensitive to the time-step and grid and has a long runtime in the high Wi case (Wi = 2) of creeping flow regime (There is no problem in Wi < 0.1). Also, when I plotted the pressure at a special point (to check the convergence), I faced some fluctuations. In addition, there are some strange structures in the streamlines (I think these are unphysical).
Is it normal for a creeping flow regime? Or related to the viscoelastic fluids? or related to my setup and solver?
How can I reduce the run time, and get stable physical results (without fluctuations)?
Thank you
alimea is offline   Reply With Quote
creeping flow, fluctuation, openfoam, runtime
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump Zev Xavier FLUENT 3 May 9, 2016 06:42
Viscoelastic fluid flow simultion by using Oldroyd-b model shubhamchauhan OpenFOAM Running, Solving & CFD 0 April 11, 2016 10:21
two fluid, volumetric/mass flow rate at different volume fractions Veronique Pe CFX 2 November 26, 2014 05:30
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 20:28
