November 25, 2021, 15:01 |
trying to debug - running into brick wall
#41 |
Alan w
Rep Power: 6 |
In a very methodical way, I am trying to debug my multiRegion case. It is composed of an air region, which incorporates a simple fairing around the radiator, and a porous region, which is the radiator itself consisting of a porous zone.
My first step was to modify the case to eliminate the radiator. In the process, I cleaned up the fairing mesh; it's good now. When I ran chtMultiRegionFoam to 200 seconds, it finished normally. Partial Success! Then, I did the same for the other zone. I deleted the radiator fairing, such that the air zone is simply a blockMesh domain. So now, the only mesh being analyzed is the radiator itself, hanging in air. When I launched the solver, it immediately failed with my old friend, the message stating: energy -> temperature conversion failed to converge. This debug version is basically identical to the heatExchanger tutorial. I closely compared the two, which only differ only in the porous zone being modelled, but I can't find any reason why my case fails, and the tutorial doesn't. As they say in France, I am gobsmacked. Attached are my runlog file, and a zip file of the case with the radiator only. I am 99.9% through my OF self course, and am being held up by this mystical problem. Please, if anyone has ideas, I would be delighted to hear them. |
December 16, 2023, 14:26 |
my *first* multiregion case - The Saga is over (I hope)! plus a question
#42 |
Alan w
Rep Power: 6 |
A year and half ago, I posted my first plea for help with a chtMultiRegion case. Over the ensuing months, I received many posts of help from the smart people in this forum. Finally Yann provided the assistance that broke the log jam. Attached is an image of the temperature flow that has me celebrating. (I hope there is no other error lurking like the one that that fooled me for months.)
This case concerns a cuboid shaped radiator in a duct. Many of the suggestions said, just look in the tutorials. However it turns out that my method of setting up the case has no equivalent in the heat transfer tutorials. These use toposet, but Yann said I don't need it; all I have to do is to make sure the radiator lines up properly with the duct, and define it that way in the meshes. And it worked. It seems to me that my method is much more representative of real world scenarios. Many times, I have seen posts from students in Formula SAE or Formula Student expressing the desire to model radiator installations for their cars, I imagine that many of them had the same problems as I did. In my opinion, the tutorials, while invaluable, can be incomplete. Here is my question: In my successful case, after having problems with stl files, I modelled the radiator with blockMeshDict. But I thought that I should also be able to do it with salome, exporting the mesh as a unv file. When I specifed the face names (e.g. inlet, outlet, etc.), ideasUnvToFoam repeatedly failed. When I made no attempt to define face names, it worked, but in paraView the image is bizarre (see attached). Ultimately, using a unv file is probably the best way, but as of now, I can't make it work. Thanks again to Yann and all the others who ventured to help me. |
December 17, 2023, 09:28 |
#43 |
Yann
Rep Power: 26 |
Hello Alan,
Thanks for your kind words, I'm glad you finally managed to reach your goal. You should be able to mesh your radiator with either snappy, blockMesh or Salome, it doesn't really matter. I won't be of any help with Salome since I don't use it, but I'm pretty sure there are people around here who can help. |
January 2, 2024, 09:11 |
chtMultiRegionFoam kappa setting goes wrong
#44 |
yingting tang
Rep Power: 2 |
I'm going to simulate electronicBoard(material:Al) cooling process with water,when I setting the metal's thermalphysicalProperties,it remind me that:
[0] --> FOAM FATAL IO ERROR: [0] Expected a '(' while reading VectorSpace<Form, Cmpt, Ncmpts>, found on line 43 the label 205 [0] [0] file: /home/zh_zhanghpc/OpenFOAM/ytTang/eletricalHT/constant/metal/thermophysicalProperties/mixture/transport/kappa at line 43. [0] [0] From function [4] [4] [4] --> FOAM FATAL IO ERROR: [4] Expected a '(' while reading VectorSpace<Form, Cmpt, Ncmpts>, found on line 0 the label 205 [4] [4] file: IOstream/mixture/transport/kappa at line 0.[5] [5] [5] --> FOAM FATAL IO ERROR: [5] Expected a '(' while reading VectorSpace<Form, Cmpt, Ncmpts>, found on line 0 the label 205 [5] [5] file: IOstream/mixture/transport/kappa at line 0. [5] [5] From function [6] [6] [6] --> FOAM FATAL IO ERROR: [6] Expected a '(' while reading VectorSpace<Form, Cmpt, Ncmpts>, found on line 0 the label 205 [6] [6] file: IOstream/mixture/transport/kappa at line 0. [6] [6] From function Foam::Istream& Foam::Istream::readBegin(const char*) [4] [4] From function Foam::Istream& Foam::Istream::readBegin(const char*) [4] in file db/IOstreams/IOstreams/Istream.C at line 92. [4] FOAM parallel run exiting [4] Foam::Istream& Foam::Istream::readBegin(const char*) [5] in file db/IOstreams/IOstreams/Istream.C at line 92. [5] FOAM parallel run exiting [5] [6] in file db/IOstreams/IOstreams/Istream.C at line 92. [6] FOAM parallel run exiting [6] [7] [7] file: IOstream/mixture/transport/kappa at line 0. [7] [7] From function Foam::Istream& Foam::Istream::readBegin(const char*) [7] in file db/IOstreams/IOstreams/Istream.C at line 92. [7] FOAM parallel run exiting [7] Foam::Istream& Foam::Istream::readBegin(const char*) [0] in file db/IOstreams/IOstreams/Istream.C at line 92. [0] FOAM parallel run exiting [0] [1] [1] [1] --> FOAM FATAL IO ERROR: [1] Expected a '(' while reading VectorSpace<Form, Cmpt, Ncmpts>, found on line 0 the label 205 [1] [1] [2] [2] [2] --> FOAM FATAL IO ERROR: [2] Expected a '(' while reading VectorSpace<Form, Cmpt, Ncmpts>, found on line 0 the label 205 [2] [2] file: IOstream/mixture/transport/kappa at line file: IOstream/mixture/transport/kappa at line 0. [1] [1] 0. [2] [2] From function Foam::Istream& Foam::Istream::readBegin(const char*) [2] in file db/IOstreams/IOstreams/Istream.C at line 92 From function Foam::Istream& Foam::Istream::readBegin(const char*) [1] in file db/IOstreams/IOstreams/Istream.C at line 92. [1] FOAM parallel run exiting [1] . [2] FOAM parallel run exiting [2] [3] [3] [3] --> FOAM FATAL IO ERROR: [3] Expected a '(' while reading VectorSpace<Form, Cmpt, Ncmpts>, found on line 0 the label 205 [3] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 6 in communicator MPI COMMUNICATOR 3 SPLIT FROM 0 with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [3] file: IOstream/mixture/transport/kappa at line 0. [3] [3] From function Foam::Istream& Foam::Istream::readBegin(const char*) [3] in file db/IOstreams/IOstreams/Istream.C at line 92. [3] FOAM parallel run exiting [3] [DESKTOP-91GJLA5:28832] 7 more processes have sent help message help-mpi-api.txt / mpi-abort [DESKTOP-91GJLA5:28832] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages my setup for metal: thermoType { type heSolidThermo; mixture pureMixture; transport constAnIsoSolid; thermo eConst; equationOfState rhoConst; specie specie; energy sensibleInternalEnergy; } mixture { specie { nMoles 1; molWeight 26.98; } thermodynamics { Cv 700; Hf 0; } transport { kappa 205; } equationOfState { rho 2.7; } } Is anyone know how can I fixed it? Any help will be appreciated!!Thanks!! |
OF 4.0 multiregion case calculate yPlus | pbnuclex | OpenFOAM Post-Processing | 6 | July 16, 2020 04:27 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
[OpenFOAM] ParaView 4.10 and OpenFOAM 2.3.0 Multiregion and decomposed case | romant | ParaView | 3 | April 7, 2014 15:42 |
Transient case running with a super computer | microfin | FLUENT | 0 | March 31, 2009 11:20 |
Turbulent Flat Plate Validation Case | Jonas Larsson | Main CFD Forum | 0 | April 2, 2004 10:25 |
