Floating Point exception (core dumped) chtMultiRegionFoam
Old   May 28, 2020, 11:43
Default Floating Point exception (core dumped) chtMultiRegionFoam
ayu12 is on a distinguished road
I am just trying to simulate the compressible flow of air within two hotplates maintained at a temperature of 1800 K. It is a 2D Simulation. I want to understand how heat transfer affects the Velocity and temperature of Air flowing within the Hot Plates. There are 2 Solid regions and 1 Fluid region. I am getting a floating-point error in the beginning itself.
To resolve the issue, i tried many cases like,
1.) I tried to run a dummy case, in order to understand if the solver is running.
PIMPLE
PIMPLE algorithm finds no convergences defined for all regions and It shifts to PISO. This is agreeable. And finally a Floating Point error. I updated the convergence criteria as well.
2.)nI rechecked my boundary conditions. For P, it is Calculated and T Zero Gradient. I kept my maxCo as 0.5.
I do understand this error is because of division by 0 but not able to point out the problem.
Can anyone help me understand what can be the issue? I am very new to OpenFoam and CFD and I am stuck at this point and not able to resolve this issue.
My Log File
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
Build  : 7-1ff648926f77
Exec   : chtMultiRegionFoam
Date   : May 28 2020
Time   : 17:40:26
Host   : "test-VBox"
PID    : 1699
I/O    : uncollated
Case   : /home/test/OpenFOAM/hotpipe2D
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create fluid mesh for region Air for time = 0
Create solid mesh for region solid1 for time = 0
Create solid mesh for region solid2 for time = 0
*** Reading fluid mesh thermophysical properties for region Air
    Adding to thermoFluid
Selecting thermodynamics package
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleEnthalpy;
    Adding to rhoFluid
    Adding to UFluid
    Adding to phiFluid
    Adding to gFluid
    Adding to hRefFluid
    Adding to ghFluid
    Adding to ghfFluid
    Adding to turbulenceFluid
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
    Adding to reactionFluid
Combustion model not active: combustionProperties not found
Selecting combustion model none
    Adding to radiationFluid
Radiation model not active: radiationProperties not found
Selecting radiationModel none
    Adding to KFluid
    Adding to dpdtFluid
    Adding to fieldsFluid
    Adding MRF
No MRF models present
    Adding fvOptions
*** Reading solid mesh thermophysical properties for region solid1
    Adding to thermos
    type            heSolidThermo;
    transport       constIso;
    thermo          hConst;
    equationOfState rhoConst;
    specie          specie;
    Adding to radiations
    Adding fvOptions
*** Reading solid mesh thermophysical properties for region solid2
    Adding to thermos
    type            heSolidThermo;
    transport       constIso;
    thermo          hConst;
    specie          specie;
    Adding fvOptions
PIMPLE: Region Air
PIMPLE: Convergence criteria found
        p: tolerance 1e-05
        U: tolerance 1e-05
        T: tolerance 1e-05
PIMPLE: Region solid1
        T: tolerance 1e-05
PIMPLE: Region solid2
        T: tolerance 1e-05
PIMPLE: Operating solver in transient mode with 1 outer corrector
PIMPLE: Operating solver in PISO mode
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4  Foam::operator/(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#5  ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam"
#6  ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam"
#7  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#8  ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam"
Floating point exception (core dumped)
My case File is attached for reference.
ayu12 is offline   Reply With Quote
Old   October 12, 2021, 11:31
Praharsha Reddy
lonewanderer is on a distinguished road
In p_rgh file give zeroGradient at inlet and fixed value at outlet
lonewanderer is offline   Reply With Quote
Floating point exception (core dumped) ramakant OpenFOAM Running, Solving & CFD 4 March 7, 2019 20:58
Floating Point Exception Error nyox FLUENT 11 November 30, 2018 12:31
Floating point exception (core dumped), running a new solver Mahyar Javidi OpenFOAM Running, Solving & CFD 6 April 7, 2018 12:43
sonicFoam - Floating point eception (core dumped) MSans OpenFOAM Running, Solving & CFD 12 August 4, 2015 05:10
[waves2Foam] setWaveParameters application, it results in a floating point exception and the core psahoo87 OpenFOAM Community Contributions 1 February 4, 2015 12:42
