pressure fluctuation when applying time varying velocity inlet
Old   November 10, 2021, 02:29
Default pressure fluctuation when applying time varying velocity inlet
chen112p's Avatar
Junting Chen
chen112p is on a distinguished road
Hello, I am using pimpleFoam to run an external aerodynamics simulation using IDDES - SA. Instead of using steady inlet flow, I recorded a flow with some turbulence then inject this flow to my inlet boundary. Velocity field is all looking good but I notice that pressure field in the domain fluctuates in some unphysical way. Here I am running the simulation using OF2012.
I noticed that this topic has been discussed in this thread: Fluctuating Pressure Fields (LES-pisoFoam)
I don't think i found a solution from this thread tho. Please drop some hints if someone knows a good way to fix it.
JT
chen112p is offline   Reply With Quote
Convergence problem of OF WUYing OpenFOAM Running, Solving & CFD 2 September 20, 2021 10:09
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
Pressure loss Velocity coupling CFXMUFFIN CFX 1 February 6, 2016 04:43
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 07:56
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
