Avoid message when using runApplication/RunParallel |
November 29, 2021, 09:09 |
Alejandro Valeije
Rep Power: 11 |
Hi everyone,
I am creating a custom Allrun file, and, since I explain through "echo" the operation I am running at each instant, I would like to avoid the message that appears when using the function runApplication or runParallel. Does anybody know how to disable that message? (without using simply the operation, because I want to avoid using mpirun instead of runParallerl) Thanks in advance. Regards, Alex |
November 29, 2021, 09:19 |
Alejandro Valeije
Rep Power: 11 |
Just found a solution, sending the operations to another log with a non-used name. Sorry for the inconveniences. Anyhow, if anybody has a cleaner approach, it'd be nice if he let me know
Regards |
November 29, 2021, 09:26 |
Rep Power: 8 |
You can redirect the output to /dev/null
"When in doubt, use brute force." -- Ken Thompson |
November 29, 2021, 09:47 |
Alejandro Valeije
Rep Power: 11 |
cma-permission-denied message for parallel running | choist31 | OpenFOAM Running, Solving & CFD | 4 | August 3, 2023 13:07 |
SIGSEGV error when running UDF | tricha122 | Fluent UDF and Scheme Programming | 2 | November 26, 2020 10:27 |
Error message in CFX solver | CFXer | CFX | 2 | July 14, 2020 06:28 |
Injection initialization generate a segmentation fault!! | zahrae | Fluent UDF and Scheme Programming | 11 | July 9, 2019 19:00 |
Error Message on es-ice [BUG] | Wendy Tjia | Siemens | 0 | February 10, 2005 08:40 |
