Solver for flotation tank case
Old   December 2, 2021, 03:03
Default Solver for flotation tank case
Muhammad Ahyar
Ahyar is on a distinguished road
I want to simulate a stirred tank that contain bubble and particle aggregation and/or breakup. my simulation has MRF region that contains a rotor to stir the fluid movement, and the bubbles size in the tank are polydisperse. which solver from openfoam that can be used to simulate this case? I've tried to use the OpenQBMM add-on to simulate my case and using polyDisperseBubbleFoam solver, but the simulation went divergent. is there any openfoam solver that can perform this case? thanks in advance.
Ahyar is offline   Reply With Quote
Fail to converge when solving with a fabricated solution zizhou FLUENT 0 March 22, 2021 06:33
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 15:13
2D flow around a circular cylinder case with interFoam solver shuoxue OpenFOAM Running, Solving & CFD 2 January 14, 2020 13:23
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
