Running rhoSimpleFoam; paraFoam aborting
Old   December 7, 2021, 12:26
Default Running rhoSimpleFoam; paraFoam aborting
Amaterasu is on a distinguished road
Greetings,
i'm currently trying to work on a problem, where i want to analyse the heat transfer of hot balls, which are beeing cooled down by flowing air.
Right now i'm just trying to keep it simple and just want to analyse the flow and the heat absorption of the air if flowed towards the hot balls. I want to use
I created a mesh with blockmesh, used snappyhexmesh on it, and when i use checkMesh, it says that there is 1 Mesh error, after doing some research it appeared to not cause any problems.
Anyways: I can run rhoSimpleFoam (kinda... i guess). It creates folders and i dont get any errors trying to run it, but when i want to see the results in paraFoam, it crashes with the following message:
paraFoam
Created temporary 'rhoSimple.OpenFOAM'
I/O : uncollated
--> FOAM Warning :
From function virtual Foam:olyMesh::readUpdateState Foam:olyMesh::readUpdate()
in file meshes/polyMesh/polyMeshIO.C at line 209
boundary changed, proceed with care.
--> FOAM Warning :
--> FOAM FATAL IO ERROR:
Cannot find patchField entry for DoppelBalls_patch24311
file: /home/mentalstrength/Desktop/foamZweiflung/Kugelschüttung/rhoSimple/10/p/boundaryField from line 25 to line 33.
From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam:imensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
in file /home/ubuntu/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 184.
FOAM exiting
"DoppelBalls" is what i called my two balls. I understand that there is some sort of problem with the patch and/or with the p-field. But the patch, which causes the error, is created by snappyHexMesh.
Also the syntax of my p-file seems correct.
Anybody knows what can cause this error?
Amaterasu is offline   Reply With Quote
error, rhosimplefoam
Running rhoSimpleFoam for Pressure Driven Flow y_jiang OpenFOAM Running, Solving & CFD 11 September 14, 2018 14:30
[OpenFOAM] Running paraFoam as a parallel job Hisham ParaView 2 September 13, 2011 09:14
[OpenFOAM] ParaFoam Error jblucca ParaView 1 June 28, 2007 02:37
[OpenFOAM] Running paraFOam shuo ParaView 11 October 26, 2006 14:43
[OpenFOAM] Both paraview and paraFoam crash on Redhat Linux WS v4 64bit sek ParaView 4 August 17, 2006 16:26
