Amal Chummar
Rep Power: 5 ![]() |
I am considering a cube with its left wall heated and all other walls as normal. i have copied the basic tutorial for flange for the heat conduction part. I have then edited the flange case and made it into cubical by including my own blockmesh file and also changing boundary conditions in the '0' folder for T file. But while running it using Allrun command i am getting errors. It is a very basic problem and since I am new to OpenFoam can get a result. When I try to open paraview it suddenly blacks-out and closes.
PLS HELP Thank you ![]() |
cube, heat conduction, laplacianfoam |
Problem with foam-extend 4.0 ggi parallel run | Metikurke | OpenFOAM Running, Solving & CFD | 1 | December 6, 2018 15:51 |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
Problem in foam-extend 4.0 ggi parallel run | Metikurke | OpenFOAM Running, Solving & CFD | 0 | February 20, 2018 06:34 |
problem in parallel run in Workbench | Mina_Shahi | CFX | 0 | September 8, 2011 11:27 |
Problem on Parallel Run Setup | Hamidur Rahman | CFX | 0 | September 23, 2007 17:11 |
