December 15, 2021, 04:56 |
tutorial heatduct with air instead of water
Rep Power: 5 |
Hello together,
I would like to change the fluid from water to air in the "heatduct" tutorial from OpenFoam V9, however the simulation breaks when I make the following changes to the thermophysicalProperties: Water: Code:
thermoType { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } mixture { // Water specie { molWeight 18; } equationOfState { rho 1000; } thermodynamics { Cp 4181; Hf 0; } transport { mu 959e-6; Pr 6.62; } } Code:
thermoType { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } mixture { specie { nMoles 1; molWeight 28.9; // [g/mol] } thermodynamics { Cp 1005; // [J/kg/K] Hf 0; } transport { mu 1.8e-05; // [kg/m/s] Pr 0.7; } } I get the following error message if I change the thermalphysicalProperties: Code:
[3] #0 Foam::error::printStack(Foam::Ostream&)[0] #0 Foam::error::printStack(Foam::Ostream&)[1] #0 Foam::error::printStack(Foam::Ostream&)[2] #0 Foam::error::printStack(Foam::Ostream&) at ??:? at ??:? at ??:? at ??:? [0] #1 Foam::sigFpe::sigHandler(int)[2] #1 [3] #Foam::sigFpe::sigHandler(int)1 Foam::sigFpe::sigHandler(int)[1] #1 Foam::sigFpe::sigHandler(int) at ??:? [2] #2 ? at ??:? at ??:? [3] #2[0] #2 ?? at ??:? [1] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" in "/lib/x86_64-linux-gnu/libc.so.6" in "/lib/x86_64-linux-gnu/libc.so.6" in "/lib/x86_64-linux-gnu/libc.so.6" [2] #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&)[3] #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&)[0] #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&)[1] #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? at ??:? at ??:? at ??:? [1] #4 Foam::operator/(Foam::UList<double> const&, Foam::UList<double> const&)[2] #4 Foam::operator/(Foam::UList<double> const&, Foam::UList<double> const&)[0] #4 Foam::operator/(Foam::UList<double> const&, Foam::UList<double> const&)[3] #4 Foam::operator/(Foam::UList<double> const&, Foam::UList<double> const&) at ??:? [2] #5 at ??:? [1] #5 at ??:? [0] #5 at ??:? [3] #5 ???? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam" [1] #6 in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam" [2] #6 in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam" [3] #6 in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam" [0] #6 ???? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam" [2] #7 __libc_start_main in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam" [3] #7 __libc_start_main in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam" [0] #7 in "/opt/openfoam9/p__libc_start_mainlatforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam" [1] #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [2] #8 in "/lib/x86_64-linux-gnu/libc.so.6" [3] #8 in "/lib/x86_64-linux-gnu/libc.so.6" [0] #8 in "/lib/x86_64-linux-gnu/libc.so.6" [1] #8 ???? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam" [7560:11981] *** Process received signal *** [7560:11981] Signal: Floating point exception (8) [7560:11981] Signal code: (-6) [7560:11981] Failing at address: 0x3e800002ecd [7560:11981] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x46210)[0x7fc307c2a210] [7560:11981] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xcb)[0x7fc307c2a18b] [7560:11981] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x46210)[0x7fc307c2a210] [7560:11981] [ 3] in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam" [7560:11982] *** Process received signal *** [7560:11982] Signal: Floating point exception (8) [7560:11982] Signal code: (-6) [7560:11982] Failing at address: 0x3e800002ece [7560:11982] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x46210)[0x7f74cdb96210] [7560:11982] [ 1] in "/opt/openfoam9/platfor/lib/x86_64-linux-gnu/libc.so.6(gsignal+0xcb)[0x7f74cdb9618b] [7560:11982] [ 2] ms/linux64GccDPInt32Opt/bin/chtMultiRegi/lib/x86_64-linux-gnu/libc.so.6(+0x46210)[0x7f74cdb96210] [7560:11982] [ 3] onFoam" [7560:11979] *** Process received signal *** [7560:11979] Signal: Floating point exception (8) [7560:11979] Signal code: (-6) [7560:11979] Failing at address: 0x3e800002ecb [7560:11979] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x46210)[0x7f2854653210] [7560:11979] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xcb)[0x7f285465318b] [7560:11979] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x46210)[0x7f2854653210] [7560:11979] [ 3] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam6divideERNS_5FieldIdEERKNS_5UListIdEES6_+0x5b)[0x7fc308826dab] [7560:11981] [ 4] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam6divideERNS_5FieldIdEERKNS_5UListIdEES6_+0x5b)[0x7f74ce792dab] [7560:11982] [ 4] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4FoamdvERKNS_5UListIdEES3_+0x59)[0x7fc3088288b9] [7560:11981] [ 5] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam6divideERNS_5FieldIdEERKNS_5UListIdEES6_+0x5b)[0x7f285524fdab] [7560:11979] [ 4] chtMultiRegionFoam(+0x4c834)[0x560aa2885834] [7560:11981] [ 6] chtMultiRegionFoam(+0x41e96)[0x560aa287ae96] [7560:11981] [ 7] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0x7fc307c0b0b3] [7560:11981] [ 8] chtMultiRegionFoam(+0x4b96e)[0x560aa288496e] [7560:11981] *** End of error message *** in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam" [7560:11980] *** Process received signal *** [7560:11980] Signal: Floating point exception (8) [7560:11980] Signal code: (-6) [7560:11980] Failing at address: 0x3e800002ecc [7560:11980] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x46210)[0x7ff6b2191210] [7560:11980] [ 1] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4FoamdvERKNS_5UListIdEES3_+0x59)[0x7f74ce7948b9] [7560:11982] [ 5] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xcb)[0x7ff6b219118b] [7560:11980] [ 2] chtMultiRegionFoam(+0x4c834)[0x560a69a27834] [7560:11982] [ 6] /lib/x86_64-linux-gnu/libc.so.6(+0x46210)[0x7ff6b2191210] [7560:11980] [ 3] chtMultiRegionFoam(+0x41e96)[0x560a69a1ce96] [7560:11982] [ 7] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0x7f74cdb770b3] [7560:11982] [ 8] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4FoamdvERKNS_5UListIdEES3_+0x59)[0x7f28552518b9] [7560:11979] [ 5] chtMultiRegionFoam(+0x4b96e)[0x560a69a2696e] [7560:11982] *** End of error message *** chtMultiRegionFoam(+0x4c834)[0x556817f09834] [7560:11979] [ 6] chtMultiRegionFoam(+0x41e96)[0x556817efee96] [7560:11979] [ 7] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0x7f28546340b3] [7560:11979] [ 8] chtMultiRegionFoam(+0x4b96e)[0x556817f0896e] [7560:11979] *** End of error message *** /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam6divideERNS_5FieldIdEERKNS_5UListIdEES6_+0x5b)[0x7ff6b2d8ddab] [7560:11980] [ 4] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4FoamdvERKNS_5UListIdEES3_+0x59)[0x7ff6b2d8f8b9] [7560:11980] [ 5] chtMultiRegionFoam(+0x4c834)[0x5590e5d31834] [7560:11980] [ 6] chtMultiRegionFoam(+0x41e96)[0x5590e5d26e96] [7560:11980] [ 7] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0x7ff6b21720b3] [7560:11980] [ 8] chtMultiRegionFoam(+0x4b96e)[0x5590e5d3096e] [7560:11980] *** End of error message *** -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun noticed that process rank 1 with PID 0 on node 7560 exited on signal 8 (Floating point exception). -------------------------------------------------------------------------- _Revolution_ |
December 25, 2021, 09:10 |
Al Csc
Rep Power: 7 |
You need to change from fluid to gas.
constant/regionProperties: fluid (fluid) -> fluid (gas) and then all the other keywords. |
Water diffusion into air | MGabr | CFX | 19 | September 3, 2023 19:06 |
compressibleInterFoam case – a flat wall air cavity filling up with water | Zeppo | OpenFOAM Running, Solving & CFD | 0 | October 3, 2015 10:01 |
3D multiphase micro model: mixing effect of air and water at the T junction | ehsanfareed | FLUENT | 2 | March 22, 2015 22:29 |
VOF-compression of air with rising water | yavuz | FLUENT | 0 | November 26, 2005 09:00 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
