Initial residuals of p increases within the piso loop of pimpleFoam |
December 20, 2021, 03:25 |
Rep Power: 5 |
Dear foamers,
I am doing a transient case using pimpleFoam. My geometry consists of a tube with constant input. I have run the case with simpleFoam and it converged (even for various # cells). I have used the U and p fields resulted from simpleFoam as the initial values for pimpleFoam. pimpleFoam starts normally and converged in the first time step but at the next steps it doesn't converge and the problem is that the initial residual of p increases within the piso loop of pimpleFoam and avoids the convergence. It is notable that when i set nCorrectors 1 it doesn't converge even in the first time step. Maybe anybody knows the reason of piso fluctuations. please help. Many thanks in advance! fvSolution solvers Code:
{ p { solver PBiCGStab;// GAMG;//PCG;// preconditioner DIC; tolerance 1e-06; relTol 0; } pFinal { $p; tolerance 1e-6; relTol 0; } "(U|k|epsilon)" { solver smoothSolver;//PBiCGStab;//PBiCG;// GAMG;// // preconditioner DILU;// diagonal;// smoother DILU;// DILUGaussSeidel;// GaussSeidel;// nonBlockingGaussSeidel;// symGaussSeidel;// nSweeps 3; tolerance 1e-08; relTol 0; minItr 50; } UFinal { $U; tolerance 1e-8; relTol 0; minItr 50; } } PIMPLE { momentumPredictor yes; correctPhi yes; nOuterCorrectors 115; nCorrectors 3; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; moveMeshOuterCorrectors false; consistent true; residualControl { U { tolerance 1e-3; relTol 0; } p { tolerance 1e-2; relTol 0; } } } relaxationFactors { fields { p 0.25; // p_rgh 0.9; pFinal 1; // Last outer loop } equations { "U|k|epsilon" 0.2; "(U|k|epsilon)Final" 1; } } Code:
PIMPLE: iteration 60 smoothSolver: Solving for Ux, Initial residual = 0.000596143, Final residual = 1.68916e-11, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.00048953, Final residual = 8.49394e-12, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.000205322, Final residual = 2.13581e-11, No Iterations 3 DICPBiCGStab: Solving for p, Initial residual = 0.0290384, Final residual = 9.97052e-07, No Iterations 120 time step continuity errors : sum local = 2.23685e-09, global = -2.09271e-10, cumulative = 1.22208e-08 DICPBiCGStab: Solving for p, Initial residual = 0.0513252, Final residual = 9.98867e-07, No Iterations 165 time step continuity errors : sum local = 2.29943e-09, global = -9.46057e-10, cumulative = 1.12747e-08 DICPBiCGStab: Solving for p, Initial residual = 0.0228054, Final residual = 9.56565e-07, No Iterations 102 time step continuity errors : sum local = 2.14037e-09, global = 2.6051e-10, cumulative = 1.15353e-08 PIMPLE: iteration 61 smoothSolver: Solving for Ux, Initial residual = 0.000600401, Final residual = 1.68889e-11, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.000489021, Final residual = 4.43221e-12, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.000125419, Final residual = 1.99905e-11, No Iterations 3 DICPBiCGStab: Solving for p, Initial residual = 0.0385374, Final residual = 9.62274e-07, No Iterations 226 time step continuity errors : sum local = 2.18719e-09, global = -1.86789e-09, cumulative = 9.66736e-09 DICPBiCGStab: Solving for p, Initial residual = 0.015498, Final residual = 7.43952e-07, No Iterations 145 time step continuity errors : sum local = 1.65077e-09, global = -1.4565e-09, cumulative = 8.21086e-09 DICPBiCGStab: Solving for p, Initial residual = 0.0227203, Final residual = 5.81333e-07, No Iterations 206 time step continuity errors : sum local = 1.29589e-09, global = -1.15134e-09, cumulative = 7.05952e-09 PIMPLE: iteration 62 smoothSolver: Solving for Ux, Initial residual = 0.000604502, Final residual = 1.34418e-11, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.0002945, Final residual = 4.25852e-12, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.000180853, Final residual = 1.63934e-11, No Iterations 3 DICPBiCGStab: Solving for p, Initial residual = 0.0125226, Final residual = 9.03802e-07, No Iterations 197 time step continuity errors : sum local = 1.99878e-09, global = -9.23917e-10, cumulative = 6.1356e-09 DICPBiCGStab: Solving for p, Initial residual = 0.0165563, Final residual = 9.59857e-07, No Iterations 229 time step continuity errors : sum local = 2.12599e-09, global = 1.05918e-09, cumulative = 7.19478e-09 DICPBiCGStab: Solving for p, Initial residual = 0.00870745, Final residual = 9.79781e-07, No Iterations 167 time step continuity errors : sum local = 2.15445e-09, global = -1.64654e-09, cumulative = 5.54824e-09 PIMPLE: iteration 63 smoothSolver: Solving for Ux, Initial residual = 0.00207671, Final residual = 9.15617e-09, No Iterations 132 smoothSolver: Solving for Uy, Initial residual = 0.00106387, Final residual = 8.38791e-09, No Iterations 90 smoothSolver: Solving for Uz, Initial residual = 0.000734466, Final residual = 9.43681e-09, No Iterations 105 DICPBiCGStab: Solving for p, Initial residual = 0.0160802, Final residual = 9.57418e-07, No Iterations 175 time step continuity errors : sum local = 6.38359e-08, global = 4.96666e-08, cumulative = 5.52149e-08 DICPBiCGStab: Solving for p, Initial residual = 0.204943, Final residual = 9.94995e-07, No Iterations 142 time step continuity errors : sum local = 8.17283e-08, global = -1.66004e-08, cumulative = 3.86145e-08 DICPBiCGStab: Solving for p, Initial residual = 0.321276, Final residual = 9.05519e-07, No Iterations 123 time step continuity errors : sum local = 8.7076e-08, global = -1.48197e-08, cumulative = 2.37949e-08 PIMPLE: converged in 63 iterations Courant Number mean: 0.00221723 max: 16.9237 deltaT = 0.000170612 Time = 0.00594538 PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = 0.000726623, Final residual = 3.21501e-12, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.00353084, Final residual = 9.0885e-12, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.000171417, Final residual = 6.08206e-12, No Iterations 3 DICPBiCGStab: Solving for p, Initial residual = 0.547564, Final residual = 9.87219e-07, No Iterations 291 time step continuity errors : sum local = 1.38683e-10, global = 8.50819e-11, cumulative = 2.38799e-08 DICPBiCGStab: Solving for p, Initial residual = 0.338699, Final residual = 3.90249e-07, No Iterations 255 time step continuity errors : sum local = 4.52846e-11, global = -4.5126e-12, cumulative = 2.38754e-08 DICPBiCGStab: Solving for p, Initial residual = 0.380801, Final residual = 8.73685e-07, No Iterations 240 time step continuity errors : sum local = 1.15928e-10, global = -9.86046e-12, cumulative = 2.38656e-08 PIMPLE: iteration 2 smoothSolver: Solving for Ux, Initial residual = 0.000918823, Final residual = 1.84937e-11, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.0102808, Final residual = 5.02138e-11, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.00029521, Final residual = 1.8008e-11, No Iterations 3 DICPBiCGStab: Solving for p, Initial residual = 0.269734, Final residual = 9.15093e-07, No Iterations 252 time step continuity errors : sum local = 1.04702e-10, global = -2.08214e-11, cumulative = 2.38447e-08 DICPBiCGStab: Solving for p, Initial residual = 0.309119, Final residual = 4.23408e-07, No Iterations 238 time step continuity errors : sum local = 4.7834e-11, global = -3.87096e-11, cumulative = 2.3806e-08 DICPBiCGStab: Solving for p, Initial residual = 0.220623, Final residual = 4.8042e-07, No Iterations 253 time step continuity errors : sum local = 5.0209e-11, global = -3.04463e-11, cumulative = 2.37756e-08 . . . PIMPLE: iteration 112 smoothSolver: Solving for Ux, Initial residual = 0.000654905, Final residual = 5.10987e-11, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.008963, Final residual = 4.70701e-10, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.002707, Final residual = 1.98632e-10, No Iterations 3 DICPBiCGStab: Solving for p, Initial residual = 0.508875, Final residual = 8.70705e-07, No Iterations 259 time step continuity errors : sum local = 1.35272e-10, global = 8.35666e-11, cumulative = 2.39468e-08 DICPBiCGStab: Solving for p, Initial residual = 0.636816, Final residual = 9.83226e-07, No Iterations 239 time step continuity errors : sum local = 1.94442e-10, global = 1.66498e-10, cumulative = 2.41133e-08 DICPBiCGStab: Solving for p, Initial residual = 0.216246, Final residual = 9.04256e-07, No Iterations 239 time step continuity errors : sum local = 9.22798e-11, global = 5.99732e-11, cumulative = 2.41732e-08 PIMPLE: iteration 113 smoothSolver: Solving for Ux, Initial residual = 0.000786775, Final residual = 5.61967e-11, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.014052, Final residual = 2.9613e-10, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.00341111, Final residual = 2.98654e-10, No Iterations 3 DICPBiCGStab: Solving for p, Initial residual = 0.30737, Final residual = 4.81297e-07, No Iterations 267 time step continuity errors : sum local = 5.46339e-11, global = -2.44855e-11, cumulative = 2.41488e-08 DICPBiCGStab: Solving for p, Initial residual = 0.318505, Final residual = 5.74335e-07, No Iterations 238 time step continuity errors : sum local = 6.78318e-11, global = 2.74993e-11, cumulative = 2.41763e-08 DICPBiCGStab: Solving for p, Initial residual = 0.316076, Final residual = 9.71893e-07, No Iterations 271 time step continuity errors : sum local = 1.17822e-10, global = 2.19671e-11, cumulative = 2.41982e-08 PIMPLE: iteration 114 smoothSolver: Solving for Ux, Initial residual = 0.000839459, Final residual = 6.56314e-11, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.0113558, Final residual = 2.80627e-10, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.00402269, Final residual = 2.05148e-10, No Iterations 3 DICPBiCGStab: Solving for p, Initial residual = 0.255311, Final residual = 9.42784e-07, No Iterations 260 time step continuity errors : sum local = 1.05578e-10, global = 5.01809e-11, cumulative = 2.42484e-08 DICPBiCGStab: Solving for p, Initial residual = 0.416368, Final residual = 9.32197e-07, No Iterations 254 time step continuity errors : sum local = 1.44675e-10, global = -2.3226e-11, cumulative = 2.42252e-08 DICPBiCGStab: Solving for p, Initial residual = 0.305066, Final residual = 7.54257e-07, No Iterations 238 time step continuity errors : sum local = 9.33397e-11, global = 7.98126e-12, cumulative = 2.42332e-08 PIMPLE: iteration 115 smoothSolver: Solving for Ux, Initial residual = 0.00383473, Final residual = 9.00047e-09, No Iterations 126 smoothSolver: Solving for Uy, Initial residual = 0.0347903, Final residual = 8.96059e-09, No Iterations 135 smoothSolver: Solving for Uz, Initial residual = 0.0268389, Final residual = 8.99541e-09, No Iterations 135 DICPBiCGStab: Solving for p, Initial residual = 0.250735, Final residual = 6.17735e-07, No Iterations 283 time step continuity errors : sum local = 2.71463e-09, global = 2.64751e-09, cumulative = 2.68807e-08 DICPBiCGStab: Solving for p, Initial residual = 0.981904, Final residual = 9.85822e-07, No Iterations 129 time step continuity errors : sum local = 2.2477e-07, global = 4.54504e-08, cumulative = 7.23311e-08 DICPBiCGStab: Solving for p, Initial residual = 0.988755, Final residual = 9.79718e-07, No Iterations 119 time step continuity errors : sum local = 4.52153e-07, global = -2.04961e-09, cumulative = 7.02815e-08 PIMPLE: not converged within 115 iterations |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
