January 14, 2022, 16:48 |
very high pressure
Gabriel
Rep Power: 4 |
Hi, iīm simulating flow through a box with vents containing 6 spheres, what i donīt understand is that the results from the simulations shows very high pressure drop between inlet and outlet (42000 kinematic pressure at inlet and -10000 at outlet). is the simulation realistic?
simpleFoam case: https://www.dropbox.com/s/pntr90nqtc...foam2.zip?dl=0 |
January 15, 2022, 09:33 |
Yes, it makes sense. Look at the velocity and you'll see that you have a velocity of around 150m/s through each vent. So the (kinematic) dynamic pressure is Pd=0.5 * U^2 = 11,250. If we assume a loss coefficient of Cd=2 for the simple orifice, then that gives a dP of 22,500 per baffle, i.e. 44,500 between inlet and outlet. That matches the pressure you quoted.
The real question is: why do you have a hurricance passing through your vents? The answer: check your boundary condition. You are forcing in air at 6.68m/s at the inlet, and then this constructs do at the vents ... to 150m/s. So, have a rethink about your BCs. The good news is that the code appears to be working nicely. |
January 19, 2022, 18:49 |
Gabriel
Rep Power: 4 |
ok thanks for your answer
High negative pressure with interPhaseChangeFoam | legione | OpenFOAM Running, Solving & CFD | 7 | July 5, 2015 10:28 |
Does star cd takes reference pressure? | monica | Siemens | 1 | April 19, 2007 11:26 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
