running openFOAM9 via FreeCAD
Old   January 23, 2022, 15:23
Default running openFOAM9 via FreeCAD
sam j
awesomeuser is on a distinguished road
Two particular commands needs to be part of Allrun script especially if flow problem solved in multiprocessors.
reconstructPar -newTimes
This command writes results into corresponding time stamps otherwise what you will have 0/
Another command also necessarily be part of Allrun script is
simppleFoam -postProcess -func wallShearStress
This will calculate wallShearStress at the wall (no-slip) BC.
This you will U, p and wallShearStress variables available to plot in Paraview.
I literally wasted 4 weeks figuring out this for a novice.
awesomeuser is offline   Reply With Quote
freecad, openfoam, paraview
Simulation just stops output writing, but keeps running blaise OpenFOAM Running, Solving & CFD 6 March 27, 2024 04:49
Running Case in Parallel Typ Main CFD Forum 5 May 11, 2020 03:43
[swak4Foam] swak4foam openfoam 7 installation problem Andrea23 OpenFOAM Community Contributions 1 February 17, 2020 18:11
Error problem while running sadia d lts tutorial kane OpenFOAM Running, Solving & CFD 2 May 26, 2018 03:38
Error Running Design of Experiments in ANSYS Fluent tytrzecki FLUENT 0 April 22, 2018 15:01
