Help with codeStream in chtMultiregionFoam case |
February 14, 2023, 08:18 |
Chris
Rep Power: 4 |
I'm trying to use codeStream to implement a very simple initial condition for a region that contains air in my case. I'm trying to solve the case in parallel with the chtMultiregionFoam solver.
The condition I need to impose is to to have 3 different temperature regions. One at T_out another one at T_max and another region between the previous two to gradually vary the temperature. My T file for that specific region is the following Code:
dimensions [ 0 0 0 1 0 0 0 ]; internalField #codeStream//uniform 400; { codeInclude #{ #include "fvCFD.H" #}; codeOptions #{ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude #}; codeLibs #{ -lmeshTools \ -lfiniteVolume #}; code #{ const IOdictionary& d = static_cast<const IOdictionary&>(dict); const fvMesh& mesh = refCast<const fvMesh>(d.db()); scalar T_out = 320; scalar T_max = 450; scalar y_o = 0; scalar y_d= 0.1; scalarField T(mesh.nCells(), T_out); forAll(T, i) { //const scalar x = mesh.C()[i][0]; const scalar y = mesh.C()[i][1]; //const scalar z = mesh.C()[i][2]; if ( ( y > y_o) && (y < y_d) ) { T[i] = T_out + (T_max-T_out)*y/y_d; } if ( y > y_d) { T[i] = T_max; } } writeEntry(os, "", T); #}; } boundaryField { free_air { type zeroGradient;//fixedValue; value uniform 300; } "air_to_receiver_(hot|mid)" { type compressible::turbulentTemperatureRadCoupledMixed; value $internalField; Tnbr T; kappaMethod fluidThermo; kappa none; } air_to_receiver_out { type compressible::turbulentTemperatureCoupledBaffleMixed; value $internalField; Tnbr T; kappaMethod fluidThermo; kappa none; } } Code:
Time = 0 Using #codeStream at line 19 in file "/home/ct/OpenFOAM/ct-9/run/iSTORE/iSTORE_conical_radiation_2/0/air/T" Using #codeStream with "/home/ct/OpenFOAM/ct-9/run/iSTORE/iSTORE_conical_radiation_2/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_71df4e2699f44fe883e845da37e52226fb0ad032.so" Creating new library in "dynamicCode/_71df4e2699f44fe883e845da37e52226fb0ad032/platforms/linux64GccDPInt32Opt/lib/libcodeStream_71df4e2699f44fe883e845da37e52226fb0ad032.so" "/opt/openfoam9/etc/codeTemplates/dynamicCode/codeStreamTemplate.C" "/home/ct/OpenFOAM/ct-9/run/iSTORE/iSTORE_conical_radiation_2/dynamicCode/_71df4e2699f44fe883e845da37e52226fb0ad032/codeStreamTemplate.C" Invoking "wmake -s libso /home/ct/OpenFOAM/ct-9/run/iSTORE/iSTORE_conical_radiation_2/dynamicCode/_71df4e2699f44fe883e845da37e52226fb0ad032" wmake libso /home/ct/OpenFOAM/ct-9/run/iSTORE/iSTORE_conical_radiation_2/dynamicCode/_71df4e2699f44fe883e845da37e52226fb0ad032 ln: ./lnInclude wmkdep: codeStreamTemplate.C Ctoo: codeStreamTemplate.C ld: /home/ct/OpenFOAM/ct-9/run/iSTORE/iSTORE_conical_radiation_2/dynamicCode/_71df4e2699f44fe883e845da37e52226fb0ad032/../platforms/linux64GccDPInt32Opt/lib/libcodeStream_71df4e2699f44fe883e845da37e52226fb0ad032.so codeStream : dictionary:"/home/ct/OpenFOAM/ct-9/run/iSTORE/iSTORE_conical_radiation_2/0/air/T" master-only-reading:0 on processor 0 have masterSize:827336 and localSize:827336 on processor 0 after waiting: have masterSize:827336 and localSize:827336 Opening cached dictionary:"/home/ct/OpenFOAM/ct-9/run/iSTORE/iSTORE_conical_radiation_2/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_71df4e2699f44fe883e845da37e52226fb0ad032.so" codeStream : dictionary:"/home/ct/OpenFOAM/ct-9/run/iSTORE/iSTORE_conical_radiation_2/0/air/T" master-only-reading:0 --> FOAM FATAL IO ERROR: Illegal dictionary entry or environment variable name "internalField" Valid dictionary entries are 1(dimensions) file: /home/ct/OpenFOAM/ct-9/run/iSTORE/iSTORE_conical_radiation_2/0/air/T from line 17 to line 17. From function bool Foam::primitiveEntry::expandVariable(const Foam::variable&, const Foam::dictionary&) in file db/dictionary/primitiveEntry/primitiveEntry.C at line 92. FOAM exiting Completed in 9 seconds I'm running OpenFoam v9. I also tried to find example in the tutorial folder but I didn't find anything similar to the think I try to do. Does anybody know where my mistake is or alternatively how else I could implement my initial condition? |
February 20, 2024, 14:59 |
Thiago Parente Lima
Rep Power: 14 |
Hi Chris,
Have you tried first to run a case analogous to the tutorial slides, setting a different value for T in an elliptical region? I am asking you because in my case not even this case compiles... If you are succesfull on it , please let us know. Regards. P.s.: sorry, the post from February 14, 2023 and not 2024 :#
Fields of interest: buoyantFoam, chtMultRegionFoam. Last edited by thiagopl; February 20, 2024 at 15:07. Reason: Didn't notice it is an old question. |
codestream, parallel |
[OpenFOAM] post-processing chtMultiRegionFoam case in paraview? | phsieh2005 | ParaView | 2 | July 15, 2016 15:05 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
Multiregion Heat Transfer + natural convection (water) with chtMultiRegionFoam | fattychickenrun | OpenFOAM | 5 | October 31, 2011 16:53 |
Error reading new case | montag dp | FLUENT | 5 | September 15, 2011 06:00 |
Transient case running with a super computer | microfin | FLUENT | 0 | March 31, 2009 11:20 |
