OpenFoam Transient Wind Velocity Problems
Old   March 19, 2022, 07:06
Default OpenFoam Transient Wind Velocity Problems
Zach Tolmie
zach6399 is on a distinguished road
Hello all, I'm quite new to OpenFoam, so in all likelihood this will be a stupid mistake on my part!
I am attempting to run a transient simulation (rhoreactingbuoyantfoam) of a gas leak, with parabolic wind conditions. I've tried mesh refinement and running with uniform wind velocity and the same thing also happens. As I increase the timestep, the velocity past the inlet increases exponentially, to supersonic speeds. This region lasts for about 20 meters, after which the velocity is flowing in the negative direction, or is close to zero.
I've attached the files for U, P and p_rgh.
Any help would be much appreciated!
Thanks,
Zach
zach6399 is offline   Reply With Quote
Old   March 19, 2022, 09:13
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
From my experience, buoyancy and addition free stream does not work very well and gib unrealistic high velocity at points where the buoyancy ends (downstream).
I have decoupled the physics for my application. May be there is another was. I would be interested reading a solution.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   March 19, 2022, 23:57
Voulet is on a distinguished road
Hello. What do you mean by «I have decoupled the physics » ? You don't add the buyoyancy term to the momentum NavierStokes Equation ?
« Debugging is what CFD is about. 5 minutes to modify your code, 5 months to find why it does not work anymore. »
Voulet is offline   Reply With Quote
Old   March 20, 2022, 00:37
piu58's Avatar
Uwe Pilz
That is not easy. But in principle, I solved the buoyancy alone and used the result as boundary conditions for a fress stream simulation.
You have to decide where the flow is buoyancy dominated. Of course you intrduce some error in the region where both, buoyancy and free stream, act. But you get a result at all.
It was a few years ago and I don't know every thing I tried. But at least a used a "mixing area" where I added the buoyancy effects (beyond the buoyancy limit) to the free stream simualtion.
Uwe Pilz
fully developed inlet velocity in openfoam mb.pejvak Main CFD Forum 0 May 17, 2019 10:15
kindly help me .. i have and error at line number 147.. m zubair Fluent UDF and Scheme Programming 0 February 10, 2019 11:25
UDF comilation error. urgent help please m zubair Fluent UDF and Scheme Programming 4 February 10, 2019 11:19
[General] Wind Velocity Henry Lau ParaView 0 April 21, 2017 20:31
twoPhaseEulerFoam, mass loss and velocity profile problems mwaqas OpenFOAM Running, Solving & CFD 0 November 14, 2014 17:44
