May 6, 2022, 09:02 |
Flashing test case openFOAM
Vittorio Cossu
Rep Power: 4 |
Hi everyone! I am new to cfd-online, but I've always read CFD stuff and you are great!
Does anybody know how to simulate a virtual wall on openfoam? I would like to simulate a burst disk, which after the rupture connects two environment at different pressure. I used codeStream to simulate different initial condition for the internal flow. My idea was that with those initial condition, the start of the transient simulates the rupture of the disk, is it appropriate? I run the simulation with cavitatingFoam since as first attempt I was trying to use an HEM model to simulate the flashing, the results shows that the pressure increase only in the region where the system was initialized at lower pressure whilst remaing constant at high pressure where the region was iniitialized at high pressure. Can anybody help? I've already post this question in the pre-processing forum but I did not receive any answer. Thank you. Best regards, Vittorio |
burst disk, cavitatingfoam, flashing flow |
Some problems in naca 0012 V&V case of NASA TMR and DPW using OpenFOAM | chengdi | OpenFOAM Running, Solving & CFD | 7 | October 5, 2019 13:20 |
Large test case for running OpenFoam in parallel | fhy | OpenFOAM Running, Solving & CFD | 23 | April 6, 2019 09:55 |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 03:18 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
