June 15, 2022, 13:19 |
DNS of sphere at Re=3700 blows up
Nikolaos Beratlis
Rep Power: 16 |
I am trying to run DNS of a sphere at Re=3700. I will be comparing the results of OpenFOAM against other codes and results in the literature.
I created an O grid for the mesh around a sphere in a cylindrical domain. The inlet is 5D from the sphere, the outlet is 20D and the radius of the cylindrical domain is 10D. Here are some photos of the mesh near the sphere. Around the sphere the grid is slightly stretched in the radial direction to cluster points near the surface of the sphere. The resolution is kept fine in a region behind the sphere up to 5D to resolve the near wake. This photo showing a cross section cut showing the grid around the sphere and the wake Another photo showing a cross section cut in the wake with crinkle clip The simulation blows up after 20 iterations. I ran the simulation with both pisoFOAM and simpleFOAM without any success. Simulationtype is laminar. Here is the output of the pisoFOAM run. Code:
Time = 0.036 Courant Number mean: 0.0422403 max: 1.36537 smoothSolver: Solving for Ux, Initial residual = 0.0587041, Final residual = 8.42802e-06, No Iterations 5 smoothSolver: Solving for Uy, Initial residual = 0.0587602, Final residual = 7.79945e-06, No Iterations 5 smoothSolver: Solving for Uz, Initial residual = 0.00212533, Final residual = 2.55993e-06, No Iterations 3 GAMG: Solving for p, Initial residual = 0.99465, Final residual = 0.0430159, No Iterations 2 time step continuity errors : sum local = 1.02157e-06, global = -6.00863e-12, cumulative = -3.02265e-08 GAMG: Solving for p, Initial residual = 0.979142, Final residual = 8.77358e-07, No Iterations 21 time step continuity errors : sum local = 2.42567e-11, global = -3.09213e-12, cumulative = -3.02296e-08 ExecutionTime = 401.43 s ClockTime = 403 s forceCoeffs forces write: Cm = -0.0331513 Cd = 0.697653 Cl = 0.0638549 Cl(f) = -0.00122385 Cl(r) = 0.0650787 Time = 0.038 Courant Number mean: 0.0422442 max: 2.85164 smoothSolver: Solving for Ux, Initial residual = 0.0998439, Final residual = 8.97566e+216, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = 0.100005, Final residual = 2.91442e+216, No Iterations 1000 smoothSolver: Solving for Uz, Initial residual = 0.00432983, Final residual = 2.49464e+215, No Iterations 1000 Here is the fvScheme file Code:
ddtSchemes { default backward; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) Gauss linear; div(phi,k) Gauss limitedLinear 1; div(phi,s) bounded Gauss limitedLinear 1; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } Code:
solvers { p { solver GAMG; tolerance 1e-06; relTol 0.1; smoother GaussSeidel; } pFinal { $p; smoother DICGaussSeidel; tolerance 1e-06; relTol 0; } "(U|k|B|nuTilda|s)" { solver smoothSolver; smoother GaussSeidel; tolerance 1e-05; relTol 0; } } PISO { nCorrectors 2; nNonOrthogonalCorrectors 0; } Code:
application pisoFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 300; deltaT 2e-03; adjustTimeStep yes; maxCo 1.0; writeControl adjustableRunTime; writeInterval 10; purgeWrite 0; writeFormat binary; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; |
June 18, 2022, 05:40 |
#2 | |
Josh Williams
Rep Power: 5 |
Alternatively, it may be a numerical issue in your solution or boundary conditions. It seems your tolerances are quite low. We typically go for like 1e-10 for pressure and 1e-8 for velocity. Also why using two different solvers for pressure (GAMG and DICGaussSiedel)? I am unsure what pressure condition you use at the outlet but if there is still recirculation at the outlet you may try a stabilising BC (totalPressure for p, inletOutlet for U). |
blow up, dns, laminar, sphere, unstable |
Possible to select Cells next to a SPHERE surface? | keepfit | OpenFOAM | 2 | November 30, 2016 15:47 |
[snappyHexMesh] Sphere in a channel by snappyHexMesh | arsalan.dryi | OpenFOAM Meshing & Mesh Conversion | 0 | November 14, 2016 16:01 |
Filtering DNS solutions Vs projecting filtered DNS solution | juliom | Main CFD Forum | 5 | May 19, 2016 16:06 |
[ICEM] meshing a sphere - large deviation from perfect sphere | murx | ANSYS Meshing & Geometry | 25 | August 15, 2012 12:37 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 12:37 |
