June 26, 2022, 08:21 |
Karman Vortex 2d- laminar
qutadah
Rep Power: 4 |
I am trying to simulate air flow around the cylinder in 2d.. The flow is laminar (Re= 100) and I am using pimpleFoam.
I am not sure what to use for my BCs for the patches... I have used slip for the cylinder in this simulation. I think it is wrong. Second, the flow does not look exactly correct right? Any help would be appreciated. Here is a video of the simulation! https://drive.google.com/drive/folde...vr?usp=sharing A photo is also uploaded! Thanks! Last edited by qutadah.r; June 27, 2022 at 15:06. Reason: pimpleFoam |
June 27, 2022, 12:33 |
Rep Power: 4 |
Dear qutadah,
can you provide more information on the case? Did you try higher Reynolds numbers? Last edited by ngbidi; June 27, 2022 at 12:44. Reason: further specify the question |
June 27, 2022, 15:08 |
qutadah
Rep Power: 4 |
I have used instead pimpleFoam (kindly read the problem description again, I have uploaded a video of the simulation). Thanks ! I actually only tried it for Re 100, and as described the flow shouldnt be oscillating at the downstream of the cylinder at that Reynolds number right? Thanks! |
June 28, 2022, 03:57 |
Santiago Lopez Castano
Rep Power: 15 |
Why you use 'slip' for a highly viscous problem?
July 6, 2022, 12:07 |
Josh Williams
Rep Power: 5 |
I cannot see any issue in the flowfield visualisation picture you show. (I did not view the video). It is oscillating, as flow over a bluff body should. You should use more quantitative way to verify if it is working or not. There will be a lot of literature for drag coefficient or other metrics for flow over a cylinder.
To echo what Santiago is implying: unless there is a key detail in your problem setup or objectives that you have excluded, I would recommend using noSlip on the cylinder walls. Outlet should be zeroGradient for velocity (or inletOutlet for improved stability). Outlet for pressure should probably be fixedValue or totalPressure. |
2dimensional, icofoam, icofoam problem, karman vortex street |
no karman vortex street occur in the simulation of the flow over a cylinder | TyuYooh | STAR-CCM+ | 0 | November 8, 2021 04:49 |
Karman vortex - steady state solution with RANS ? | CellZone | Main CFD Forum | 4 | September 28, 2018 03:11 |
Karman Vortex street | Apocolapse | STAR-CCM+ | 2 | December 12, 2011 10:53 |
karman vortex street help please | SSeth | STAR-CCM+ | 7 | January 10, 2011 11:31 |
Kármán vortex street in cavitating flow behind bodies in the cavitation tunnel | L. Könözsy | Main CFD Forum | 0 | April 17, 2000 13:16 |
