February 4, 2022, 08:10 |
Dimension Error after overPotentialFoam
Rep Power: 7 |
Hello, i am trying to fall a sphere in an atmosphere which has about 1 billion Re with tet meshes. To success this, i believe first i get steady solution with overRhoSimpleFoam. And make the solution faster i decided to run overPotentialFoam as initialization before overRhoSimpleFoam. However, when i run overRhoSimpleFoam after initialization, it gives dimension errors like:
U[0 1 -2 0 0 0 0 ] + [rho*MRFZoneList:acceleration)[1 -2 -2 0 0 0 0] ] in openfoam Is there anyone have a guess about what might go wrong ? (Dimensions in BC is correct) |
August 8, 2022, 08:24 |
Rep Power: 7 |
No answer, really ?
overset |
dimension problem in reactingParcelFoam | farzadmech | OpenFOAM Programming & Development | 3 | March 17, 2020 16:01 |
FloTHERM XT dimension parameters not working | DB99 | FloEFD, FloWorks & FloTHERM | 0 | August 13, 2019 16:24 |
[ANSYS Meshing] Refinement dimension is not working | Tasos | ANSYS Meshing & Geometry | 0 | May 13, 2017 09:07 |
How to get a single value from a volScalarField including the dimension | safre | OpenFOAM Programming & Development | 18 | May 20, 2016 08:01 |
buoyantPimpleDyMFoam dimension mismatch between Uf and phi | Sumit07 | OpenFOAM Programming & Development | 2 | June 17, 2015 03:55 |
