Simulating a Poiseuille flow through a 3D square channel |
September 18, 2022, 02:56 |
Mrigank Dhingra
Hi Foamers,
So I have been trying to simulate a pressure driven 3-dimensional channel flow through a square channel. I want to solve for a laminar, incompressible steady state flow so therefore, I am using simpleFoam as my solver. The issue is that when I plot a U_magnitude plot right at the center of the flow domain, my V_max is not twice (or around two times) the V_avg which I use in order to calculate the pressure difference between the inlet and outlet. My V_max comes out to be around 7-8 times the V_avg. Now, I have tried to solve the problem with different boundary conditions but the result is always the same. As for my geometry/channel, I am simply using the blockMesh's stl file and running the simulations within it. Does anyone have any sort of idea on why is this happening? Could It be that I am setting my problem incorrectly, e.g. incorrect solver or boundary conditions? Any sort of suggestions/help would be greatly appreciated! |
openfoam, poiseuille flow |
unable to run dynamic mesh(6dof) and wave UDF | shedo | Fluent UDF and Scheme Programming | 0 | July 1, 2022 17:22 |
How to validate a 3D poiseuille flow in a rectangular channel? | dhouha | FLOW-3D | 1 | August 30, 2017 11:06 |
Enabling Open Channel Flow Sub-Model in Mixture model | cod213 | FLUENT | 0 | January 10, 2017 13:40 |
Modeling the mixing of air and kerosene in a flow channel | StefanG | CFX | 3 | June 11, 2012 20:21 |
help! flow in square duct | chris | Main CFD Forum | 2 | December 22, 2003 10:13 |
