Heat flux boundary in incompresible solver
Old   November 14, 2022, 19:00
Default Heat flux boundary in incompresible solver
Christian Pinzón
davcrisp is on a distinguished road
Hi everyone
I simulated a case in wich I have a wall with a heat flux (q=2000 W/m2) using pimpleFoam, I fix a boundary condition as a fixGradient in the next way:
 plate
        type fixedGradient; //fixed heat flux b.c.
        gradient uniform 2000;
I postprocesed the data using Plot over Line in Paraview so as to get h (convective coefficient), I extract the T_i results and then I calculate h=q/(T_inf-T_i). My question is, It possible to calculate in that way? or I should have to calcule with other stepts or in other way, because when I calculate that I get some results (figure 1) arround 20 times the expected value. (figure 2).
It is correct to used that boundary in a scalar transport temperature file in that way? Thanks
davcrisp is offline   Reply With Quote
Fail to converge when solving with a fabricated solution zizhou FLUENT 0 March 22, 2021 06:33
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 10:00
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 16:08
Enforce bounds error with heat loss boundary condition at solid walls Chander CFX 2 May 1, 2012 20:11
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 21:25
