uniformValue table meaning in propeller tutorial |
March 9, 2015, 20:20 |
Dear all,
is my following interpretation correct? Code:
inlet { type uniformFixedValue; uniformValue table ( (0 (0 0 0)) (0.01 (0 -15 0)) (100 (0 -15 0)) ); value $internalField; } the meaning is : - from time 0 to 0.01s the velocity varies linearly from 0 to -15m/s - from time 0.01 to 100s the velocity stays constant at -15m/s right? thank you in advance donQi |
March 10, 2015, 07:20 |
Rep Power: 11 |
Yes, it's correct for the velocity component (Y). X and Z stays as zeros
October 29, 2022, 08:32 |
Sakun
Rep Power: 6 |
i know this a old thread but can i apply this "table" condition for compressible cases ? specially for pressure ? thank you, |
October 31, 2022, 03:32 |
Yann
Rep Power: 26 |
Sure you can, as long as you adapt the syntax (scalar instead of vector). There are several BC which can be used with tables, depending on the OpenFOAM version you are using. Regards Yann |
October 31, 2022, 05:26 |
#5 | |
Sakun
Rep Power: 6 |
Hi Yann, Thank you very much for your kind reply, I am using openFOAM v2112, This is my "p" file in my simulation so i need to give pressure gradually for the simulation, Since i am having unstable pressure condition I am really grateful if you can help me on this Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 97251; boundaryField { INLET { //type freestreamPressure; //freestreamValue uniform $pOut; type totalPressure; p0 uniform 115775; value uniform 115775; // Optional entries U U; phi phi; rho rho; //type fixedValue; //value uniform 84636.34; } OUTLET { //type freestreamPressure; //freestreamValue $internalField; type fixedValue; value uniform 97251; //type fixedFluxPressure; } CASCADE { type zeroGradient; } "(TOP|BOTTOM)" { type cyclicAMI; } frontAndBackPlanes { type empty; } } // ************************************************************************* // |
October 31, 2022, 06:00 |
Yann
Rep Power: 26 |
Something like this should do the job, up to you to adjust it to your needs:
OUTLET { type uniformFixedValue; uniformValue table ( (0 0) (0.01 97251) (100 97251) ); value $internalField; } Cheers, Yann |
October 31, 2022, 07:02 |
#7 | |
Sakun
Rep Power: 6 |
so adjusted total pressure to uniform total pressure bc as below, Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 97251; boundaryField { INLET { //type freestreamPressure; //freestreamValue uniform $pOut; /* type totalPressure; p0 uniform 115775; value uniform 115775; // Optional entries U U; phi phi; rho rho; */ //type fixedValue; //value uniform 84636.34; type uniformTotalPressure; p0 table ( (0 10000) (100 20000) (500 30000) (1000 40000) (2000 50000) (3000 60000) (4000 70000) (5000 80000) (6000 90000) (7000 100000) (8000 110000) (9000 115775) ); } OUTLET { //type freestreamPressure; //freestreamValue $internalField; type fixedValue; value uniform 97251; //type fixedFluxPressure; } CASCADE { type zeroGradient; } "(TOP|BOTTOM)" { type cyclicAMI; } frontAndBackPlanes { type empty; } } // ************************************************************************* // when i running the simulation i realize pressure is already too high in paraview, when its meant to be in a range of 70000-80000 pa between 3000- to 4000 iterations according to the table. does this mean inserting the table for total pressure is not working or do i have to do the table values for the fixedvalues as well. |
October 31, 2022, 08:11 |
Yann
Rep Power: 26 |
Are you sure the pressure is too high?
It is not very clear on your screenshot but the inlet pressure seems to be close to what you are expecting. To make sure you can load only your inlet patch in paraview and check the pressure values. If your concern is related to what is going on inside the domain, then this is another topic (your boundary condition only defines values on the boundary). Does it make sens to start your simulation with a total pressure of 10000 Pa at the inlet while you already have a fixed static pressure of 97251 Pa at the outlet? A better approach would probably be to start with a pressure drop close to zero and increase inlet pressure up to the pressure drop you aim for. Regards, Yann |
October 31, 2022, 08:46 |
#9 | ||
Sakun
Rep Power: 6 |
apologies for the low quality picture. you are correct actually, it seems inlet p is in the range of 100000 and 120000. i attached a picture of inlet pressure bc contour. i have posted (1 & 2 below) my problem in the forum months ago but did not get a reply since 1) How to inset 2 different pressure values in "p" file 2) Static and Total Pressure Values are Same at the Compressor Blade Quote:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 97251; boundaryField { INLET { //type freestreamPressure; //freestreamValue uniform $pOut; /* type totalPressure; p0 uniform 115775; value uniform 115775; // Optional entries U U; phi phi; rho rho; */ //type fixedValue; //value uniform 84636.34; type uniformTotalPressure; p0 table ( (0 50) (100 100) (200 500) (300 1000) (500 2000) (1000 4000) (2000 6000) (4000 8000) (6000 10000) (7000 20000) (8000 30000) (9000 40000) (10000 50000) (11000 60000) (12000 70000) (13000 80000) (14000 90000) (15000 100000) (16000 110000) (18000 115775) ); } OUTLET { //type freestreamPressure; //freestreamValue $internalField; type fixedValue; value uniform 97251; //type fixedFluxPressure; } CASCADE { type zeroGradient; } "(TOP|BOTTOM)" { type cyclicAMI; } frontAndBackPlanes { type empty; } } // ************************************************************************* // Again i am really thankful for you for supporting me in this case ,casue you are the only person who replied for this issue. |
November 2, 2022, 03:46 |
#10 |
Yann
Rep Power: 26 |
Hi Sakun,
On you screenshot, the pressure on the inlet patch is 115775 Pa, which is the total pressure value your assigned in your boundary condition (p0=115775 Pa is the last line of your table). Do you get any flow inside your domain? What velocity do you get at inlet? Regards, Yann |
November 2, 2022, 17:55 |
#11 | |
Sakun
Rep Power: 6 |
Understood, really appriciate for the guidence. p File, Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 97251; boundaryField { INLET { //type freestreamPressure; //freestreamValue uniform $pOut; type totalPressure; p0 uniform 115775; value uniform 115775; //type fixedValue; //value uniform 84636.34; } OUTLET { //type freestreamPressure; //freestreamValue $internalField; type fixedValue; value uniform 97251; } CASCADE { type zeroGradient; } "(TOP|BOTTOM)" { type cyclicAMI; } frontAndBackPlanes { type empty; } } // ************************************************************************* // U File, Code:
/*--------------------------------*- C++ -*----------------------------------* \ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { INLET { //type pressureInletOutletVelocity; //value uniform $Uinlet; //type freestreamVelocity; //freestreamValue uniform $Uinlet; //value uniform $Uinlet; //type fixedValue; //value uniform (232.43 20.34 0); type pressureDirectedInletVelocity; inletDirection uniform (0.631623456 -0.775275312 0); //geometric inlet angle is 50.83 value uniform (0 0 0); } OUTLET { //type inletOutlet; //inletValue uniform (0 0 0); //value $internalField; //type zeroGradient; type pressureInletOutletVelocity; value $internalField; } CASCADE { type noSlip; } "(TOP|BOTTOM)" { type cyclicAMI; } frontAndBackPlanes { type empty; } } // ************************************************************************* // I am running the simulation using only pressure values. (tot_pressure=115775 and static_pressure=97251) Even though paper has mentioned(attached picture) that, there is a 0.7 mach speed at the inlet, i did not apply to the U file because i do not have the speed of sound for that particular mach number. Thank you, Regards, Sakun |
November 3, 2022, 03:35 |
#12 |
Yann
Rep Power: 26 |
Sure you cannot impose both pressure and velocity values at the inlet. What I meant was: have you checked the velocity computed at the inlet and what values do you get there? Yann |
November 3, 2022, 07:54 |
#13 | |
Sakun
Rep Power: 6 |
I attached a picture of INLET before the divergence and velocity was 3.6 m/s. and the other picture was the velocity at the INLET when i continue the simulation even after the divergence, which has a velocity of 160 m/s. Thank you, Best regards, |
Problem on Fluent Tutorial: Horizontal Film Boilig | Feng | FLUENT | 2 | April 13, 2013 05:34 |
propeller tutorial | openfoam_user | OpenFOAM Running, Solving & CFD | 0 | February 8, 2012 04:02 |
Looking for tutorial for rotating propeller for Marine Applications | naimishharpal | STAR-CCM+ | 0 | February 7, 2011 22:12 |
a propeller 2 way fsi | kantored | CFX | 9 | April 11, 2007 14:51 |
Propeller thrust at diff. advance ratio (CFX 5.7) | Zoltan | CFX | 9 | April 27, 2005 08:23 |
